Late model "metric" wheels on an old Mopar ?? #3106768
12/30/22 07:54 PM
12/30/22 07:54 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I like the look of some of the wheels that are coming on the late models such as the Chargers and Challengers. Just wondering what the issues might be mounting them one older Mopar with 4-1/2" bolt spacing. Would appreciate first-hand knowledge. Seems to me Mopar made 114.3mm bolt spacing for a reason !!
Re: Late model "metric" wheels on an old Mopar ?? [Re: Stanton] #3106781
12/30/22 08:39 PM
12/30/22 08:39 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Old Mopars are 5 on 4-1/2 aka 5 on 114.3 mm.
The new stuff is 5 on 115 mm, close enough to force on, but I wouldn't co it.
You're forcing the wheel stud to go sideways and it isn't designed for that load.
Wheel offset is another issue, late model stuff is a very positive offset (wheel center is pushed out in the barrel) so they're really deep on the backside.
Old 15x7's have a 4.25 backspacing so the center is slightly towards the front, but nothing close to what late model wheels are.
Late models also use a different hub bearing setup and don't have the protruding dust cap.
The dust cap on old cars usually sticks out to far to use the center caps using late model factory style wheels.
Re: Late model "metric" wheels on an old Mopar ?? [Re: SNK-EYZ] #3106786
12/30/22 08:58 PM
12/30/22 08:58 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
None of these issues are insurmountable. I stand corrected on the Mopar bolt pattern BUT the current Ford bolt pattern is 114.3 - which is bang on 4-1/2"
Wheel offset ... maybe not an ideal solution but thicker longer studs and wheel spacers solve that one as well as addressing the dust cap issue.
The rear can also be resolved by using a wider rear end. Not exactly a cheap solution but if you're having a rear end built adding a couple inches would probably be no additional cost.
Re: Late model "metric" wheels on an old Mopar ?? [Re: Stanton] #3106797
12/30/22 09:56 PM
12/30/22 09:56 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Mopars and Fords have a different center hub diameter, what makes a wheel hub centric.
It centers the wheel on the hub so you're not relying on the studs to center it.
IIRC Mopars are 2.75 and Fords are smaller about 2.6 roughly.
It means that the Ford wheels won't seat on the hubs all the way ( factory Ford wheel won't fit in a Mopar).
Re: Late model "metric" wheels on an old Mopar ?? [Re: SNK-EYZ] #3106801
12/30/22 10:07 PM
12/30/22 10:07 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I am running steelies that fit the following on my 51 Plymouth. Hub centering fits, as does the bolt pattern.
CHRYSLER 300 2005-2009
DODGE CHALLENGER 2009
DODGE CHARGER 2006-2011
DODGE MAGNUM 2005-2008
Re: Late model "metric" wheels on an old Mopar ?? [Re: SNK-EYZ] #3106829
12/30/22 11:51 PM
12/30/22 11:51 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
How many aftermarket wheel manufacturers ask what center bore you need when ordering wheels?!? How many millions of cars are running around relying on the tapered lug nuts to center the wheels?
My mention of Ford wheels was only to make the point that “late model” wheels still share the same bolt pattern as our old mopes.
Re: Late model "metric" wheels on an old Mopar ?? [Re: Stanton] #3106835
12/31/22 12:39 AM
12/31/22 12:39 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I scored a pair of "Ford" chrome wheels years ago at JC penney's for CHEAP CHEAP CHEAP!!!! Took them to a machine shop and had them open up the centers to fit my 64 Polara. COOL!!!! within 300 miles the rims were cracking as the centering rib I had them cut out was also a stiffening device. spank spank
Re: Late model "metric" wheels on an old Mopar ?? [Re: Stanton] #3106864
12/31/22 04:55 AM
12/31/22 04:55 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
They may share the same bolt pattern, but that doesn't necessarily mean that they will bolt on and fit, which is why I posted the info to clarify that there will be problems if someone tries to bolt them on.
Back in the 80's I was the store manager of a BF Goodrich tire store where we specialized is custom wheels.
What worked on cars back then is a different thing from modern wheels and tires since everything has an extremely short sidewall now.
The taller sidewall absorbed a lot of potential vibration problems back then, short sidewalls won't do that.
Modern aftermarket wheel use hub centering rings to keep the wheel true on the hub.
A custom wheel dealer that's any good knows that.
These are simply the facts, I'm simply trying to make people aware of them. shruggy
Re: Late model "metric" wheels on an old Mopar ?? [Re: Stanton] #3106875
12/31/22 07:34 AM
12/31/22 07:34 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Dunno if newer Mopars are really diff bolt pattern BUT, 4 1/2” inches ARE 114.3 mm.
Re: Late model "metric" wheels on an old Mopar ?? [Re: NachoRT74] #3106890
12/31/22 09:06 AM
12/31/22 09:06 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
late model mustangs use 114.3 bolt pattern.
i have seen the older torque thrust styled wheels from them installed on older mopars.
perception is 90% of reality
Re: Late model "metric" wheels on an old Mopar ?? [Re: Stanton] #3106928
12/31/22 12:15 PM
12/31/22 12:15 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Irrelevant since the OP is asking about OEM rims.
Re: Late model "metric" wheels on an old Mopar ?? [Re: Sniper] #3106960
12/31/22 02:24 PM
12/31/22 02:24 PM
moparx Offline
moparx  Offline
the hub register diameter on our toys is 2.810.
the wheel register inside diameter is 2.815-2.820.
as to the new stuff, i do not know.
beer
Re: Late model "metric" wheels on an old Mopar ?? [Re: SNK-EYZ] #3106967
12/31/22 02:32 PM
12/31/22 02:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
valid points IMO up
Sometimes people will do as they want and experience the consequences later. Reminds me of my brother in law whose buddy was helping him reassemble a New failed motor ( LONG STORY, short version) I looked at the rod bearings and told him the rods needed to be resized as they were obviously egg shaped. His buddy, local dirt track racer said we run em' like this all the time. I even offered to pay for the resizing. NOPE, friend says they're good we're putting it together. He made almost 2 laps before it spun 3 bearings. He wound up selling the entire car for pennies on the $.
I later thought that I should've asked his buddy how many races have you finished? , and then how many have you won? whistling
Re: Late model "metric" wheels on an old Mopar ?? [Re: Stanton] #3106995
12/31/22 03:29 PM
12/31/22 03:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I ran some factory 17" 2007 dodge charger 5 spoke aluminum wheels on my 68 cuda I converted to large bolt pattern. The rear bolted on and fit perfectly because I used an early B body rear end the offset was just right. The front took a little more creativity, the large bolt pattern discs already set the wheels out further but I still had to run I think a 1/4 spacer. I also had to machine a taper onto the end of the hub to get it to fit inside the wheel center and I installed the grease caps after installing the wheels and it worked great, I had it as high as 140 MPH with no issues. I think also on the front I had to install slightly longer studs if I remember right but it was 16 years ago I did all this so it's a little fuzzy.
Re: Late model "metric" wheels on an old Mopar ?? [Re: Mr T2U] #3107054
12/31/22 07:19 PM
12/31/22 07:19 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I did that with my '68 300, it required wheel spacers because of the wheel offset on a modern wheel compared to older wheels. The lug pattern matched no problem though.
Re: Late model "metric" wheels on an old Mopar ?? [Re: Blusmbl] #3107072
12/31/22 08:34 PM
12/31/22 08:34 PM
Mr T2U Offline
Mr T2U  Offline
this swap might have some MINOR problems on old mopars.. nothing over complicated.
the bolt circle is the same. Ford at 114.3MM and Mopar at 4.5" or exactly the same at 114.3
the Ford center hubs are 73.1MM and a Mopar wheel at 2.81" or 71.3MM. a difference of 1.8MM. a SMALL spacer MIGHT be required. road wheels are lug centric so maybe not. user should make this decision.
the lug seats are conical so they use the same lug nuts
as posted the late Ford wheels have a more of negative offset, usually around 30-40MM or about 1 1/2" depending on what model they were originally designed for, so a spacer will probably be needed..
