Push rod oiling #3106495
12/29/22 09:12 PM
12/29/22 09:12 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
I currently have a set of Comp EDM lifters and was wanting to confirm that I could use them for push rod oiling. I would like to use a ball on ball push rod and cup adjusters to help a little with kick out on my Crane Gold rocker arms. The Cranes to oil properly force quite a bit of distance between the rocker and pushrod. On my current engine I lose over .030 of lift due to the pushrod kicking out at a full lift.
What are the other options to gain pushrod oiling?
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Push rod oiling [Re: clovis] #3106525
12/29/22 11:31 PM
12/29/22 11:31 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Whether you can use them for pushrod oiling will depend on whether or not there is an oil hole in the pushrod cup in the lifter.
Re: Push rod oiling [Re: clovis] #3106584
12/30/22 10:30 AM
12/30/22 10:30 AM
NC
440Jim Offline
440Jim  Offline
NC
AMC lifters use pushrod oiling
Re: Push rod oiling [Re: clovis] #3106682
12/30/22 02:44 PM
12/30/22 02:44 PM
You have to have lifters that are made for pushrod oiling, have you thought about using a set of spray bar valve covers?
If not that may be your best option for oiling the top end full time scope
Re: Push rod oiling [Re: clovis] #3106692
12/30/22 03:20 PM
12/30/22 03:20 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
A problem with mounting a SBM cam on a set of v blocks is that all 5 of the cam journals are a different diameter.
The cam should be mounted on centers if you’re going to measure lobe taper by running an indicator across the lobe(referring to the other thread).
SF edm lifters for a Mopar are AMC lifters....... so they are configured for PR oiling.
If you want to use PR oiling exclusively, you need to use rockers that are PR oiling compatible.
Many(including Cranes) are not.
Re: Push rod oiling [Re: fast68plymouth] #3106782
12/30/22 08:41 PM
12/30/22 08:41 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
I have an extra set of normal Comp solid lifters, they do have a hole in the cup where the pushrod sits but I didn't know how it would gain oil pressure since the sides of the lifter are solid with no cut out or hole (like the EDM lifters)
'75 Plymouth Duster
Re: Push rod oiling [Re: clovis] #3107960
01/03/23 11:09 AM
01/03/23 11:09 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
A hole in the lifter cup does not guarantee that they support pushrod oiling. I think most lifters I've seen have that hole. That is probably a common part for all lifters, oil-through and not. The lifter body needs to have orifices in the reduced diameter band that will connect to the hole in the lifter seat cup to provide oiling.
