Re: Weird RAM issue
[Re: B3422W5]
#3105592
12/26/22 07:46 AM
12/26/22 07:46 AM
Posts: 1 sdv
paiyaan8
sdv
I went through HELL on the TIPM, lost the right trailer light, then would lose the BUS occasionally between the cab and the engine compartment, then other lights started being intermittent. mobdro 2022
Re: Weird RAM issue
[Re: paiyaan8]
#3105769
12/26/22 07:03 PM
12/26/22 07:03 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
I went through HELL on the TIPM, lost the right trailer light, then would lose the BUS occasionally between the cab and the engine compartment, then other lights started being intermittent. My wipers died , right turn signal lost its mind , truck stalled 5 times in 2 days , lights stay on with switch off , Im going to try and hard reset and clean all the plugs and connectors . The main 12v cable at the tipm is pretty corroded
Re: Weird RAM issue
[Re: 493_DART]
#3105887
12/27/22 11:45 AM
12/27/22 11:45 AM
Posts: 19,406 north of coder
moparx
those corroded connections can cause all kinds of goofy problems. be sure to look closely at that connection to see if the corrosion/green death goes into the cable under the insulation. more than likely it does, and a replacement cable is the best/only solution. sorry to have to say that, but i have replaced way too many cables that have had that happen.
Re: Weird RAM issue
[Re: paiyaan8]
#3106846
12/31/22 01:17 AM
12/31/22 01:17 AM
Posts: 406 California City, CA
dart440
California City, CA
I lost right trailer light also on my 04 Ram 2500 because of bad TIPM. Everything else worked fine.
After many years, I just traded the truck in on a new Ram...fixed the problem instantly!
Chuck
When you work on Spaceships for a living, how bad can a workday be?
Re: Weird RAM issue
[Re: crowbait]
#3109871
01/07/23 07:23 PM
01/07/23 07:23 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
TIPM. 99%. They corrode inside between the layers of circuit boards and where the pins go into the plugs. Horrible design! Bought one of these trucks a while back. Ended up replacing the TIPM and 6 of the plugs on the bottom. NOT a 15 minute repair but the truck has been running 5 years now. Lots of small wires need lots of patients. I told him the fuse box was bad 3 weeks ago, didn’t have money to get another
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Weird RAM issue
[Re: crowbait]
#3109937
01/07/23 10:24 PM
01/07/23 10:24 PM
Posts: 18,419 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
TIPM. 99%. They corrode inside between the layers of circuit boards and where the pins go into the plugs. Horrible design! Bought one of these trucks a while back. Ended up replacing the TIPM and 6 of the plugs on the bottom. NOT a 15 minute repair but the truck has been running 5 years now. Lots of small wires need lots of patients. A lot more than that. There are many small mini relays just like the common Bosh relays that fail.
Re: Weird RAM issue
[Re: NITROUSN]
#3110094
01/08/23 03:53 PM
01/08/23 03:53 PM
moparx
i have taken one of those things apart "just because". not sure where it came from, but i knew i would never use it, so i had a fun time. as crowbait said, i found a little corrosion between a few pins and plugs between the layers, and i thought to myself, it was an overly complicated/costly way to make an item. i wonder how many "atta boy's" the engineer that came up with this idea got...........
