Re: Bearing "shelf life"
[Re: DoubleD]
#3105642
12/26/22 11:14 AM
12/26/22 11:14 AM
Posts: 2,112 Byron, NY
W.I.N. Racing
Byron, NY
What could possibly change?
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Hot 340]
#3105651
12/26/22 11:31 AM
12/26/22 11:31 AM
Posts: 3,076 Michigan
A727Tflite
I've read recently that NEW opened/unsealed engine bearings have a shelf life...even in a dry and CLEAN environment . What say ye? Never heard this before.
I guess some do have the date stamped on them after all. Date code is not only used for “shelf life”. Used for inventory control, recall, etc. If it makes you feel any better I have several sets of Mopar bearings left over that are in their original cardboard packages. I have used bearings from this collection, that are from the late 60’s. Not a problem with any of them. Likely the only threat to a bearing in storage is moisture and that should be evident. Acids in oil from use in an engine are likely more harsh than anything a bearing would see in storage.
[Re: Hot 340]
#3105653
12/26/22 11:34 AM
12/26/22 11:34 AM
Posts: 957 Chicago
PurpleBeeper
Chicago
I guess some do have the date stamped on them after all. Greased and in their original package? Their "shelf life" is longer than you will be alive, so don't worry about it.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Pacnorthcuda]
#3105725
12/26/22 03:46 PM
12/26/22 03:46 PM
Posts: 4,206 New York
polyspheric
New York
Ever heard of "tin whiskers"? This is a phenomenon in which, under special circumstances, tin surfaces develop tiny branches (like a crystal) that grow outward and short out printed circuit boards. Does it only happen with current flow? I don't know.
Boffin Emeritus
[Re: polyspheric]
#3105728
12/26/22 04:02 PM
12/26/22 04:02 PM
Posts: 2,923 A shed in England
Tig
A shed in England
Ever heard of "tin whiskers"? This is a phenomenon in which, under special circumstances, tin surfaces develop tiny branches (like a crystal) that grow outward and short out printed circuit boards. Does it only happen with current flow? I don't know. Current flow can occur with dissimilar metals.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: A727Tflite]
#3105743
12/26/22 05:02 PM
12/26/22 05:02 PM
Posts: 3,395 Pa
Hot 340
Pa
I guess some do have the date stamped on them after all. Date code is not only used for “shelf life”. Used for inventory control, recall, etc. If it makes you feel any better I have several sets of Mopar bearings left over that are in their original cardboard packages. I have used bearings from this collection, that are from the late 60’s. Not a problem with any of them. Likely the only threat to a bearing in storage is moisture and that should be evident. Acids in oil from use in an engine are likely more harsh than anything a bearing would see in storage. Same. I have a bunch too from early 70's. Just seeing if anyone else heard this before
[Re: Hot 340]
#3105792
12/26/22 09:14 PM
12/26/22 09:14 PM
moparpollack
Lil Herman
Lil Herman
85086
Rant on shelf-life! When I was in the military quality assurance always harped shelf-life importance. For example an unopened tube of RTV that was expiring in 30 days would be sent to scrap. But if a mechanic used it on a jet engine that day it could fly for years with no problem.
[Re: Tig]
#3106319
12/29/22 11:08 AM
12/29/22 11:08 AM
Posts: 8,165 Plymouth, MI
Blusmbl
Plymouth, MI
Current flow can occur with dissimilar metals. x2. That's how thermocouples work, known dissimilar metals generate a small voltage and you can measure temperature if you know which metals are being used.
