Bearing "shelf life" #3105614
12/26/22 09:50 AM
12/26/22 09:50 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I've read recently that NEW opened/unsealed engine bearings have a shelf life...even in a dry and CLEAN environment . What say ye? Never heard this before.
I guess some do have the date stamped on them after all.
Re: Bearing "shelf life" [Re: Hot 340] #3105625
12/26/22 10:19 AM
12/26/22 10:19 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Probably info provided by a study financed by the bearing companies.
Re: Bearing "shelf life" [Re: Hot 340] #3105639
12/26/22 11:10 AM
12/26/22 11:10 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I say BS.
Re: Bearing "shelf life" [Re: Hot 340] #3105640
12/26/22 11:11 AM
12/26/22 11:11 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
makes about as much sense as an expiration date on rock salt.....
Re: Bearing "shelf life" [Re: DoubleD] #3105642
12/26/22 11:14 AM
12/26/22 11:14 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
What could possibly change?
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Bearing "shelf life" [Re: W.I.N. Racing] #3105647
12/26/22 11:22 AM
12/26/22 11:22 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Airborne solvents, sunlight (not likely), ozone?
Boffin Emeritus
Re: Bearing "shelf life" [Re: DoubleD] #3105648
12/26/22 11:25 AM
12/26/22 11:25 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I was a millwright in a chemical plant, when it closed we had several replacement electric motors that we threw away. I asked about selling them and was told that they couldn't because the bearings go bad sitting on the shelf. I called B.S., then put them in the dumpster.
Re: Bearing "shelf life" [Re: Hot 340] #3105651
12/26/22 11:31 AM
12/26/22 11:31 AM
A727Tflite Offline
A727Tflite  Offline
Date code is not only used for “shelf life”. Used for inventory control, recall, etc.
If it makes you feel any better I have several sets of Mopar bearings left over that are in their original cardboard packages. I have used bearings from this collection, that are from the late 60’s. Not a problem with any of them. Likely the only threat to a bearing in storage is moisture and that should be evident.
Acids in oil from use in an engine are likely more harsh than anything a bearing would see in storage.
Re: Bearing "shelf life" [Re: Hot 340] #3105653
12/26/22 11:34 AM
12/26/22 11:34 AM
Chicago
PurpleBeeper Offline
Chicago
Greased and in their original package? Their "shelf life" is longer than you will be alive, so don't worry about it.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Bearing "shelf life" [Re: W.I.N. Racing] #3105655
12/26/22 11:42 AM
12/26/22 11:42 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
If you ever tried to use rock salt from last year you will find it's a large block of salt now. I would suppose it depends on what the bearing surfaces are made of. It's possible the surfaces could start to form corrosion/rust but i think you would be able to see that. I remember years ago when TRW made bearings they where individually sealed and placed in a cardboard holder so they couldn't rub against each other. Ever look how Mahle bearings are packaged?
Re: Bearing "shelf life" [Re: Moparite] #3105664
12/26/22 12:34 PM
12/26/22 12:34 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If you're so curious, why not ask the manufacturer !
Re: Bearing "shelf life" [Re: Stanton] #3105690
12/26/22 01:57 PM
12/26/22 01:57 PM
Kirkland, Washington
Pacnorthcuda Offline
I think it’s about metal migration….tin/lead alloys tend to migrate over time with copper and bronze and change properties.
Re: Bearing "shelf life" [Re: Pacnorthcuda] #3105725
12/26/22 03:46 PM
12/26/22 03:46 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Ever heard of "tin whiskers"?
This is a phenomenon in which, under special circumstances, tin surfaces develop tiny branches (like a crystal) that grow outward and short out printed circuit boards.
Does it only happen with current flow? I don't know.
Boffin Emeritus
Re: Bearing "shelf life" [Re: polyspheric] #3105728
12/26/22 04:02 PM
12/26/22 04:02 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Current flow can occur with dissimilar metals.
Re: Bearing "shelf life" [Re: Tig] #3105734
12/26/22 04:47 PM
12/26/22 04:47 PM
NC
440Jim Offline
440Jim  Offline
NC
I will pay the shipping to take those unused "old" bearings off your hands.
Don't put them in the landfill ... grin
Re: Bearing "shelf life" [Re: A727Tflite] #3105743
12/26/22 05:02 PM
12/26/22 05:02 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Same. I have a bunch too from early 70's. Just seeing if anyone else heard this before
Re: Bearing "shelf life" [Re: Hot 340] #3105792
12/26/22 09:14 PM
12/26/22 09:14 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Rant on shelf-life! When I was in the military quality assurance always harped shelf-life importance. For example an unopened tube of RTV that was expiring in 30 days would be sent to scrap. But if a mechanic used it on a jet engine that day it could fly for years with no problem. shruggy
Re: Bearing "shelf life" [Re: moparpollack] #3106204
12/28/22 08:22 PM
12/28/22 08:22 PM
Cab_Burge Online work
Cab_Burge  Online Work
If the new bearings, rings, pistons and any other motor hard part look good and measure correctly I will run them scope up twocents
Re: Bearing "shelf life" [Re: Tig] #3106319
12/29/22 11:08 AM
12/29/22 11:08 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
x2. That's how thermocouples work, known dissimilar metals generate a small voltage and you can measure temperature if you know which metals are being used.
Re: Bearing "shelf life" [Re: Cab_Burge] #3106336
12/29/22 12:17 PM
12/29/22 12:17 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I bought two sets of Clevite 77 rod bearings for my 340 almost twenty years ago when I built it. If I ever put it back together, I'll use the spare set that's been sitting in my basement on a shelf all this time.
