driveshaft question #3104393
12/21/22 11:36 PM
12/21/22 11:36 PM
CA.
RAY1969CARS Offline OP
CA.
Hi guys I wanted to move my rear back
How far can I safely move the rear and back without getting a new driveshaft?
Thank you for your. Input
Mopar or no car
Re: driveshaft question [Re: RAY1969CARS] #3104426
12/22/22 02:55 AM
12/22/22 02:55 AM
Mopar or no car
On which car?
Re: driveshaft question [Re: Cab_Burge] #3104460
12/22/22 10:23 AM
12/22/22 10:23 AM
CA.
CA.
69 dart street n strip
Re: driveshaft question [Re: RAY1969CARS] #3104498
12/22/22 11:29 AM
12/22/22 11:29 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
How do you plan to move the rear back and to where , the wheel tubs aren't real big
Re: driveshaft question [Re: JohnRR] #3104533
12/22/22 12:46 PM
12/22/22 12:46 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If the front driveshaft yoke isn't supported well in the trans (tailshaft bushing), you'll have problems with that.
I'd be nervous at around 1/2", though I've done 1/4" without issues on a Duster street car.
A-bodies don't have much tail weight as it is, so I prefer moving the front lip of the wheelhouse forward.
Depending on the individual car (they vary, even side/side on same car), you can gain 3/4" - 1 1/4".
I'm assuming we're talking about larger-diameter rear tires & interference at the traditional spot.
Also, look in the stock tubs at the contours that can interfere...
Re: driveshaft question [Re: topside] #3104587
12/22/22 03:22 PM
12/22/22 03:22 PM
BDW Offline
BDW  Offline
Interesting question, so just how much engagement is needed for the yoke into the transmission?
I see people say, push all the way in and pull out 1”.
So is 2” too much to pull out, just where is too much?
Re: driveshaft question [Re: BDW] #3104592
12/22/22 03:33 PM
12/22/22 03:33 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
Santa5 Merry Christmas Moparts ! wave Hi , Are you using the Factory Bellows Ballon TailShaft Seal ? or one of the Aftermarket Slim seals ? Makes a Difference in seal to yoke , But the measurement is from the Case End , to Centerline of U-Joint . On A-Body's and F-Body's it's 3.50" , and on B-Body's and E-Body's it's 3.750" .
Re: driveshaft question [Re: 1969ronnie] #3104723
12/22/22 10:19 PM
12/22/22 10:19 PM
BDW Offline
BDW  Offline
Ok, but the question is, how much deviation is acceptable
Re: driveshaft question [Re: BDW] #3104771
12/23/22 01:37 AM
12/23/22 01:37 AM
I think Mopar FSM recommend pushing the tranny yoke all the way in and then pull it out .750, 3/4 inch, with all the cars weight on the tires for center to center measuring: scope:
I've used that method on a lot of Mopars cars for years with no regrets up scope twocents
Re: driveshaft question [Re: RAY1969CARS] #3104783
12/23/22 03:29 AM
12/23/22 03:29 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Can't be answered with given information.
May have anywhere from very deep to very shallow engagement to start.
No idea why you want to move the rear end.
Put it where you want then share how much slip yoke engagement you have.
Re: driveshaft question [Re: INTMD8] #3104800
12/23/22 08:42 AM
12/23/22 08:42 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
My max would be 1". That's with one of the long factory yokes. If I'm building a shaft, 3/4, max. Need to take suspension type and anticipated squat or separation into consideration.
Moving a rear back is the wrong direction BTW. Maybe on a street car if you're trying to avoid cutting the wheel opening. Maybe.
Re: driveshaft question [Re: CMcAllister] #3104900
12/23/22 02:04 PM
12/23/22 02:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The inside bore of factory slip yokes isn't splined all the way, the first inch or so isn't splined, so the actual spline engagement is less than it appears from the outside. I wouldn't extend the yoke more than the factory dimension.
