driveshaft question
#3104393
12/21/22 11:36 PM
12/21/22 11:36 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Hi guys I wanted to move my rear back How far can I safely move the rear and back without getting a new driveshaft?
Thank you for your. Input
Mopar or no car
Re: driveshaft question
[Re: RAY1969CARS]
#3104426
12/22/22 02:55 AM
12/22/22 02:55 AM
Posts: 43,225 Bend,OR USA
Cab_Burge
Mopar or no car On which car?
[Re: RAY1969CARS]
#3104498
12/22/22 11:29 AM
12/22/22 11:29 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
How do you plan to move the rear back and to where , the wheel tubs aren't real big
[Re: RAY1969CARS]
#3104783
12/23/22 03:29 AM
12/23/22 03:29 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Can't be answered with given information.
May have anywhere from very deep to very shallow engagement to start.
No idea why you want to move the rear end.
Put it where you want then share how much slip yoke engagement you have.
[Re: INTMD8]
#3104800
12/23/22 08:42 AM
12/23/22 08:42 AM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
My max would be 1". That's with one of the long factory yokes. If I'm building a shaft, 3/4, max. Need to take suspension type and anticipated squat or separation into consideration.
Moving a rear back is the wrong direction BTW. Maybe on a street car if you're trying to avoid cutting the wheel opening. Maybe.
[Re: CMcAllister]
#3104900
12/23/22 02:04 PM
12/23/22 02:04 PM
Posts: 25,871 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The inside bore of factory slip yokes isn't splined all the way, the first inch or so isn't splined, so the actual spline engagement is less than it appears from the outside. I wouldn't extend the yoke more than the factory dimension.
