PerTronix wiring #3104008
12/20/22 04:40 PM
12/20/22 04:40 PM
Falcon, CO
71pettyblue Offline OP
Falcon, CO
The owner of a 1967 RT that I have been working on, asked me to install a PerTronix conversion kit in the stock distributor. The instructions call for bypassing the ballast resistor. I'm sure some members have done this before. What is the best way to wire the red wire to 12 volts?
Several years ago I had suggested to using a MOPAR electronic ignition setup, but he wanted to keep his car/engine stock.
Thanks,
Tony
Tony
Retired Mopar Enthusiast
Re: PerTronix wiring [Re: 71pettyblue] #3104013
12/20/22 04:53 PM
12/20/22 04:53 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Are you changing to a PerTronix coil? The coil has to be designed to run on 12v. If the owner wants the engine compartment to look stock...a lot of people gut the back of the stock ballast and put a jumper wire back there. It looks stock but a full 12v goes to the coil. Since the coil is getting 12v, you can use that as your power feed.
Re: PerTronix wiring [Re: burdar] #3104031
12/20/22 06:10 PM
12/20/22 06:10 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
I agree done a few of them,worked great thats the way i done it.
Re: PerTronix wiring [Re: burdar] #3104048
12/20/22 07:13 PM
12/20/22 07:13 PM
Falcon, CO
Falcon, CO
Using a MSD Blaster II
Tony
Re: PerTronix wiring [Re: 71pettyblue] #3104130
12/20/22 10:28 PM
12/20/22 10:28 PM
Falcon, CO
Falcon, CO
I modified a new ballast and replaced the resistor with a solid 14g wire. I sealed the wire and tested the continuity.
Thanks guys, that was an easy modification.
Tony
Tony
Re: PerTronix wiring [Re: 71pettyblue] #3104229
12/21/22 12:24 PM
12/21/22 12:24 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Tony
Also what I did on my RR Dang she runs a lot better.....which shows I suck at setting points.... lol
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
