UPPER CONTROL ARM BUSHING COLLAR / SLEAVE #3103424
12/18/22 08:54 PM
12/18/22 08:54 PM
milwaukee
superbird Offline OP
milwaukee
Does anyone know where these can be purchased ?
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: superbird] #3103501
12/19/22 07:14 AM
12/19/22 07:14 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
wave Roger Gibson and Frank Badelson sell them . drive
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: 1969ronnie] #3103502
12/19/22 07:18 AM
12/19/22 07:18 AM
1969ronnie Offline
1969ronnie  Offline
wrench I usually buy a few extra Sets when I order them , I also install them on Vehicles that do not have them as stock , as a Reinforcement / Improvement . XmasPengs
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: 1969ronnie] #3103513
12/19/22 08:49 AM
12/19/22 08:49 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
I just went through Gibson's catalog and couldn't find them listed. Where did you find them?
Gibson Catalog
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: 6PakBee] #3103523
12/19/22 09:44 AM
12/19/22 09:44 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Gibson Catalog
Call Frank in Virginia. Just keep trying him, sometimes he is very busy
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: VCODE] #3103528
12/19/22 09:54 AM
12/19/22 09:54 AM
milwaukee
milwaukee
l
Left a message and a email this morning
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: superbird] #3103539
12/19/22 10:46 AM
12/19/22 10:46 AM
milwaukee
milwaukee
Frank had 2 left
Thanks for the help guys
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: superbird] #3103542
12/19/22 11:09 AM
12/19/22 11:09 AM
moparx Offline
moparx  Offline
a side note concerning the upper control bushing[s], in particular MOOG brand kit #K408. [4pcs for both arms]
in the last couple of weeks, i have purchased 3 of these kits, and EACH one was 0.015 OVERSIZE than the stock bushings, and these kits were not the "problem solver" line.
the bushing needed for the arms is 1.170 outside diameter, and the ones in these kits were 1.185 outside diameter.
just ONE MORE quality issue MOOG seems to not care about, and another one i can add to the list of bad MOOG parts going back 15-20 years i have personally experienced. mad down
i finally found a kit of the same number that was "old stock", and surprise ! it measured the correct 1.170 outside diameter !
the only reason i went back down this rabbit hole, was the guy insisted on MOOG bushings, although i tried my best to persuade him to another brand.
bringing this to others attention so you can avoid the frustration...................
rant over.........
beer
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: moparx] #3103608
12/19/22 02:52 PM
12/19/22 02:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
rant over.........
beer
moog = junk for a long time now , they get their parts from an Asian source that supplies more than just moog .
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: JohnRR] #3103610
12/19/22 02:58 PM
12/19/22 02:58 PM
North Dakota
North Dakota
Okay then, does anyone have the dimensions of the sleeves, ID, OD, thickness?
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: 6PakBee] #3103738
12/19/22 09:16 PM
12/19/22 09:16 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
From an installed factory original:
Inside diameter - interference fit over bushing diameter 1.168", maybe 1.167".
Outside diameter - 1.381".
Length - 5/8"
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: kentj340] #3103769
12/19/22 10:36 PM
12/19/22 10:36 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Length - 5/8"
Could be easily made wink
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: kentj340] #3103851
12/20/22 09:55 AM
12/20/22 09:55 AM
North Dakota
North Dakota
Length - 5/8"
Excellent!!! Thanks so much. Mr. Lathe and I can go to work.
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: 6PakBee] #3103868
12/20/22 10:32 AM
12/20/22 10:32 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I guess my question is why? Control arm isn't going to move once installed.
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: Sniper] #3103897
12/20/22 12:38 PM
12/20/22 12:38 PM
A727Tflite Offline
A727Tflite  Offline
The UCA “tube” goes oval during hard maneuvers with out the sleeve.
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: TJP] #3103931
12/20/22 01:47 PM
12/20/22 01:47 PM
moparx Offline
moparx  Offline
Length - 5/8"
i made a bunch of these sleeves/collars [whatever you want to call them] many years ago. very simple to make, .002 press fit, and the diameter and length are not critical dimensions as there is lots of room around them after installation. just get a chunk of 1 3/8" [1.375] diameter mild steel bar stock and start cutting. bore the inside diameter to size for a few inches depth, then cut off your needed amount of collars. rinse and repeat if you need more. no need to turn the od if you start with 1 3/8" stock.
beer
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: 6PakBee] #3104142
12/20/22 11:13 PM
12/20/22 11:13 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Length - 5/8"
Be sure to measure your own bushing OD before boring the sleeve ID. Bushing ODs could vary.
Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE [Re: kentj340] #3104260
12/21/22 02:48 PM
12/21/22 02:48 PM
1969ronnie Offline
1969ronnie  Offline
XmasPengs Agree with above Post . 2 Sizes of Control Arm Bushings Being Made today . 1 Size for ORIGINAL Upper Arms , and Another Size for the CHINESE Re-Pop Arms . Moog uses for Example Part # 123 for Original Arms , and Part # 123B for the Chinese Arms . Frank B sent me a bag of those Sleeves to do 6 Vehicles for $100 . I know My local Machine Shops get $100 per Hour . So unless You have access to a lathe , or a Machinist Buddy , Just call Frank B ! Merry Christmas Moparts ! Santa5
