Re: UPPER CONTROL ARM BUSHING COLLAR / SLEAVE
[Re: 6PakBee]
#3103523
12/19/22 09:44 AM
12/19/22 09:44 AM
Posts: 2,398 White Plains, NY
VCODE
White Plains, NY
Roger Gibson and Frank Badelson sell them . I just went through Gibson's catalog and couldn't find them listed. Where did you find them? Gibson Catalog Call Frank in Virginia. Just keep trying him, sometimes he is very busy
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: superbird]
#3103542
12/19/22 11:09 AM
12/19/22 11:09 AM
Posts: 20,235 north of coder
moparx
a side note concerning the upper control bushing[s], in particular MOOG brand kit #K408. [4pcs for both arms] in the last couple of weeks, i have purchased 3 of these kits, and EACH one was 0.015 OVERSIZE than the stock bushings, and these kits were not the "problem solver" line. the bushing needed for the arms is 1.170 outside diameter, and the ones in these kits were 1.185 outside diameter. just ONE MORE quality issue MOOG seems to not care about, and another one i can add to the list of bad MOOG parts going back 15-20 years i have personally experienced. i finally found a kit of the same number that was "old stock", and surprise ! it measured the correct 1.170 outside diameter ! the only reason i went back down this rabbit hole, was the guy insisted on MOOG bushings, although i tried my best to persuade him to another brand. bringing this to others attention so you can avoid the frustration................... rant over.........
[Re: moparx]
#3103608
12/19/22 02:52 PM
12/19/22 02:52 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
a side note concerning the upper control bushing[s], in particular MOOG brand kit #K408. [4pcs for both arms] in the last couple of weeks, i have purchased 3 of these kits, and EACH one was 0.015 OVERSIZE than the stock bushings, and these kits were not the "problem solver" line. the bushing needed for the arms is 1.170 outside diameter, and the ones in these kits were 1.185 outside diameter. just ONE MORE quality issue MOOG seems to not care about, and another one i can add to the list of bad MOOG parts going back 15-20 years i have personally experienced. i finally found a kit of the same number that was "old stock", and surprise ! it measured the correct 1.170 outside diameter ! the only reason i went back down this rabbit hole, was the guy insisted on MOOG bushings, although i tried my best to persuade him to another brand. bringing this to others attention so you can avoid the frustration................... rant over......... moog = junk for a long time now , they get their parts from an Asian source that supplies more than just moog .
Mainstream Media is the new Pravda
[Re: JohnRR]
#3103610
12/19/22 02:58 PM
12/19/22 02:58 PM
Posts: 10,931 North Dakota
6PakBee
North Dakota
Okay then, does anyone have the dimensions of the sleeves, ID, OD, thickness?
[Re: 6PakBee]
#3103738
12/19/22 09:16 PM
12/19/22 09:16 PM
Posts: 1,661 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
From an installed factory original:
Inside diameter - interference fit over bushing diameter 1.168", maybe 1.167".
Outside diameter - 1.381".
Length - 5/8"
[Re: kentj340]
#3103851
12/20/22 09:55 AM
12/20/22 09:55 AM
6PakBee
North Dakota
Length - 5/8" Excellent!!! Thanks so much. Mr. Lathe and I can go to work.
[Re: Sniper]
#3103897
12/20/22 12:38 PM
12/20/22 12:38 PM
Posts: 3,171 Michigan
A727Tflite
I guess my question is why? Control arm isn't going to move once installed. The UCA “tube” goes oval during hard maneuvers with out the sleeve.
[Re: 6PakBee]
#3104142
12/20/22 11:13 PM
12/20/22 11:13 PM
kentj340
Cut and Shoot, TX
Length - 5/8" Excellent!!! Thanks so much. Mr. Lathe and I can go to work. Be sure to measure your own bushing OD before boring the sleeve ID. Bushing ODs could vary.
