Hemi inner Studs #3102194
12/14/22 11:09 AM
12/14/22 11:09 AM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
The holes are tapped thru into the intake runner, has or does any one back fill the tapped hole with a high temp resin so there is no flow disruption?
Re: Hemi inner Studs [Re: RATTRAP] #3102247
12/14/22 01:23 PM
12/14/22 01:23 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Usually the stud slightly protrudes int the port and get polished to match.... That’s what I was taught and do twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Hemi inner Studs [Re: W.I.N. Racing] #3102262
12/14/22 01:59 PM
12/14/22 01:59 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
I would agree, but the ARP 7/16 KB studs do not have enough thread length, There about 1/4 to 3/8 shy from making it thru the stage V head intake runners.
Re: Hemi inner Studs [Re: RATTRAP] #3102323
12/14/22 04:34 PM
12/14/22 04:34 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes, but I bet it will still run good.
2011 Drag Pak Challenger
