Page 5 of 6 1 2 3 4 5 6
Re: SURGING Six Pack carbs [Re: mopar346] #310216
06/01/14 11:41 AM
06/01/14 11:41 AM
unless the idle speed screw is jacked way up for whatever reason I'm thinking the way high idle speed and the lean surge are both from a vac leak (just thinkin out loud before I have my coffee)
Re: SURGING Six Pack carbs [Re: lokalik] #310217
06/01/14 11:42 AM
06/01/14 11:42 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
not sue if this matters, just trying to help with ideas. what is your manifold vac and what power valve are you using?
I haven't double checked it in this set configuration but 12ish at the time I have and I am running a 6.5. I verified that it wasn't ruptured Friday when I took the pictures of the metering plate. At this point I am listening to just about anything.
Careful, your character's showing!
Re: SURGING Six Pack carbs [Re: mopar346] #310218
06/01/14 02:44 PM
06/01/14 02:44 PM
Try adjusting the outboard idle mixture screws in the base plates to 1/4 to 1/3 out from gently bottomed out I found out the hard way that reducing or enlarging the idle mixture bleeds ended up affecting the AFR from idle to WOT Lots of gremlins out there
Re: SURGING Six Pack carbs [Re: RapidRobert] #310219
06/01/14 11:26 PM
06/01/14 11:26 PM
mopar346 Offline
mopar346  Offline
That is the common logic but I'll be darned if I can find it, possibly from the bottom of the intake but no signs of sucking up oil. I cant say I know a to check the bottom with it assembled. The other thing that leans away from that is that it idles pretty much fine with the 64 jets.
Re: SURGING Six Pack carbs [Re: Cab_Burge] #310220
06/01/14 11:35 PM
06/01/14 11:35 PM
mopar346 Offline
mopar346  Offline
That is where they are. I was able to adjust most of my idle issue out with a little more timing and some adjusting today but it has me a 38* on total mechanical advance and 46* with the vacuum, so I have the vacuum unplugged currently. I think I am gonna pull the distributor tomorrow and work on shorting the mechanical. It's running a touch rich for my liking but not bad, better rich than lean that's for sure.
Re: SURGING Six Pack carbs [Re: mopar346] #310221
06/02/14 12:20 PM
06/02/14 12:20 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Did you get the opportunity to block off all vacuum lines and components to the intake/carbs?
Pulling the intake and re-installing it with known good procedures and blocking vac ports will quickly remove those sources of potential problem.
Running rich is not right. It seems (and is correct) that the problem is most apparent when you are getting the fuel mixture close to where it is optimal.
Vac leak remains highly suspect.
Re: SURGING Six Pack carbs [Re: srt] #310222
06/02/14 12:30 PM
06/02/14 12:30 PM
mopar346 Offline
mopar346  Offline
Yes, I blocked off all vacuum lines at one point. I am beginning to think the intake is coming off but want to work with the timing first, I can get it real close but it throughs my total timing too high for comfort. I need to ask some advance questions but will start another tread for that.
Re: SURGING Six Pack carbs [Re: mopar346] #310223
06/02/14 01:52 PM
06/02/14 01:52 PM
I'd suggest keeping this all in the same thread. 36-38 is a tried and true BB advance total (not counting vac adv) so with you capping the can You are OK for the moment. I would continue searching for the culprit then we can fine tune the timing later. yes timing gets finalzied before carburetion but we have an issue to find and fix first
Re: SURGING Six Pack carbs [Re: RapidRobert] #310224
06/02/14 02:07 PM
06/02/14 02:07 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Are the butterflies closing all the way? I was at a car show yesterday and talking to a guy that had richness problems. He took apart brand new carbs and found out the butterflies were not closing all the way. Just a suggestion.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: SURGING Six Pack carbs [Re: RapidRobert] #310225
06/02/14 08:35 PM
06/02/14 08:35 PM
mopar346 Offline
mopar346  Offline
It's a 340 and I considered keeping it in one place but thought a separate thread on the timing might be in order. And then there is the one on the plugs.
Yuck, I will double check but they seem to be.
Re: SURGING Six Pack carbs [Re: mopar346] #310226
06/03/14 11:07 PM
06/03/14 11:07 PM
mopar346 Offline
mopar346  Offline
Bit the bullet today and pulled the intake, there was just too many things lining you to say vacuum leak. I found one thing that was suspect but not conclusive, I'm letting it sit overnight and will fire it midday tomorrow and see what if anything changed. I just knew if I didn't it would be nawing at me on my drive and heaven forbid it caused a problem on the road and I had to deal with it or worse a failure I couldn't deal with quickly. I report back tomorrow.
Re: SURGING Six Pack carbs [Re: mopar346] #310227
06/04/14 11:21 PM
06/04/14 11:21 PM
mopar346 Offline
mopar346  Offline
Well I used a Mr. Gasket ultra seal gasket and the only thing it did was make my choke stove not work due to the intake not getting hot enough and it now has a longer warm start than before replacing the intake gasket. I have monkeyed with this thing for 2 weeks and it has gone down hill from where I had it originally. Everytime I go back to my basic settings it runs properly and just has the surge. I have to leave Friday morning so hopefully I have it where nothing will go wrong until I get to PA and I can work on the distributor up there.
I am beginning to wonder is the setting by Tom and Dayclona for best performance or for best behavior? Cause short of the Carter pump and the distributor I have done everything to the T with poor results. I know common thought is I am screwing something up or I don't know what I am doing but it's funny my settings make it run right and everything works properly.
Re: SURGING Six Pack carbs [Re: mopar346] #310228
06/05/14 12:09 AM
06/05/14 12:09 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Out of curiosity,what carb base gasket are you using?If you are using the thin black gasket they will never seal if the base is not square,the only gasket I would ever use is the 2/32" O.E.M. tan cardboard gasket.
where in PA might you be going ?
Re: SURGING Six Pack carbs [Re: 62maxwgn] #310229
06/05/14 12:33 AM
06/05/14 12:33 AM
mopar346 Offline
mopar346  Offline
Doylestown, I work for Fred Beans 2 weeks a month. If you are close I'm bringing it to you!
Well I think I am running the black ones, where can I get the tan ones tomorrow??? My mine concern at this point is damaging it while driving, I can live with it's misbehaving until I get it ironed out. In PA, I have a few Mopar friends that can look at it, obviously whatever I am overlooking I will continue to overlook.
Right now I have 36* total putting it at about 46* with the vacuum advance. Is there reason to be concerned about that timing? I am driving roughly 550 miles Friday and another 550 Sunday.
Re: SURGING Six Pack carbs [Re: mopar346] #310230
06/05/14 12:47 AM
06/05/14 12:47 AM
36 total is conservative normal BB amount. The extra 9 deg added in from the can is normal. If it ain't pinging from too light of spring combo (iirc it was not) then timingwise you are OK. EDIT 18 on the crank from the can as likely the 9 is the # stamped on the arm
Re: SURGING Six Pack carbs [Re: RapidRobert] #310231
06/05/14 12:57 AM
06/05/14 12:57 AM
mopar346 Offline
mopar346  Offline
Robert, It is a 340 6 pack. The thread was started several years ago by Alan and I found it in a search and wondered if he figured his out, his was a 440. So in your view and I still OK with those numbers?
Thank you
Re: SURGING Six Pack carbs [Re: mopar346] #310232
06/05/14 01:05 AM
06/05/14 01:05 AM
You're good my friend
Re: SURGING Six Pack carbs [Re: RapidRobert] #310233
06/05/14 01:07 AM
06/05/14 01:07 AM
mopar346 Offline
mopar346  Offline
Thank you, ignore the PM.
Re: SURGING Six Pack carbs [Re: mopar346] #310234
06/05/14 01:08 AM
06/05/14 01:08 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I doubt you can get them tomorrow unless you find a dealer that may have them in stock,the pt.# is P4529060,three base gaskets and three air horn gaskets,I keep extra's but that wont help you now
And Doylestown is 228 miles east !!
Re: SURGING Six Pack carbs [Re: 62maxwgn] #310235
06/05/14 08:44 AM
06/05/14 08:44 AM
mopar346 Offline
mopar346  Offline
Thanks for the part number. Yea, 228 makes it a little rough for one day after work but, if I spend another week on it that might not seem like an issue. My biggest regret right now is that I blocked the cross overs and now my choke doesn't work properly, I am gonna have to undo that in short order, rather than get hung up trying to fix something that wasn't broke. Never had an intake run cold enough not to work the choke stove around here and I usually don't run 195* t-stats either, strange.
