Page 4 of 6 1 2 3 4 5 6
Re: SURGING Six Pack carbs [Re: mopar346] #310196
05/30/14 07:40 PM
05/30/14 07:40 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
3
Careful, your character's showing!
Re: SURGING Six Pack carbs [Re: mopar346] #310197
05/30/14 07:42 PM
05/30/14 07:42 PM
mopar346 Offline
mopar346  Offline
Re: SURGING Six Pack carbs [Re: mopar346] #310198
05/30/14 07:44 PM
05/30/14 07:44 PM
mopar346 Offline
mopar346  Offline
IT's skipping some of my post so I don't know if I am repeating myself but..........
These are pictures of my metering block and bowl so hopefully someone can tell me if they are 340 or 440 pieces.
Re: SURGING Six Pack carbs [Re: mopar346] #310199
05/30/14 07:47 PM
05/30/14 07:47 PM
mopar346 Offline
mopar346  Offline
Well I modified my distributor today and put the 64 jets back in and returned it to my base settings. I regained control of my idle and it performs extremely well again with the exception that the surge it back/still there. Starts fine, hot started fine, accelerates cleaning and smoothly, idles well down to 600 or so if I wanted. Would have no need to cure anything if it wasn't for the surge. I ordered a set of 66s today that I will install tomorrow, it will be too rich I believe but I can at least see if it solves the surge and go from there.
What determines if a picture post or if it is an attachment? I posted them all the same way. Maybe it's the text???
Re: SURGING Six Pack carbs [Re: mopar346] #310200
05/30/14 08:48 PM
05/30/14 08:48 PM
mopar346 Offline
mopar346  Offline
Well I modified my distributor today and put the 64 jets back in and returned it to my base settings. I regained control of my idle and it performs extremely well again with the exception that the surge it back/still there. I ordered a set of 66s today that I will install tomorrow, it will be too rich I believe but I can at least see if it solves the surge and go from there.
I also took some pictures of the metering block and the bowl so maybe someone can tell me if they are 340 or 440 pieces.
Re: SURGING Six Pack carbs [Re: mopar346] #310201
05/30/14 08:55 PM
05/30/14 08:55 PM
mopar346 Offline
mopar346  Offline
Re: SURGING Six Pack carbs [Re: mopar346] #310202
05/30/14 11:13 PM
05/30/14 11:13 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The 6610 block is 340 also as is the bowl which incidentally if that's the way you took it off ,float level is way to high.
Re: SURGING Six Pack carbs [Re: 62maxwgn] #310203
05/31/14 01:43 AM
05/31/14 01:43 AM
mopar346 Offline
mopar346  Offline
Thank you, what problems will the 340 block and bowl on a 440 center cause? I set the float level at the bottom of the window with sight glass per Tom's instructions, I think Dayclona's call for halfway up the glass. It isn't loading up and I cant tell that I am getting bleed over in the carb.
Any suggestion on the surge other than going to 66s?
Another question, should the secondaries hold vacuum when pulled in the port? It activates but doesn't hold, the pods will hold if I have them in my hand and push the diaphram in and hold my finger over the hole. When I have it mounted to the carb it doesn't hold and I hear it bleeding off inside. I double checked a 440 set up I have and it is the same. AND they definitely seem to be fully engaging when I am on it.
Re: SURGING Six Pack carbs [Re: mopar346] #310204
05/31/14 01:54 AM
05/31/14 01:54 AM
mopar346 Offline
mopar346  Offline
Is that a date code in the bowl, Jan.82.
Re: SURGING Six Pack carbs [Re: mopar346] #310205
05/31/14 10:39 AM
05/31/14 10:39 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
There is a air bleed inside the venturi behind the vacuum diaphragm,if you look down inside you will see a small hole cover it with you finger and the diaphragm tube at the same time,it should hold vacuum.On the float level,you will notice the sight plug is higher on the center carb,you can go higher on the ends but will probably have a problem if you go much higher on the center.Just finished this set,sight plug location is very easy to see.
Date code on bowl is 82.
Next post has air bleed location.
Re: SURGING Six Pack carbs [Re: 62maxwgn] #310206
05/31/14 10:54 AM
05/31/14 10:54 AM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
any chance manifold or booster leak is causing vacuum fluctuations?
I chased more than one holley surge/idle issue caused by problems in those two components.
Re: SURGING Six Pack carbs [Re: srt] #310207
05/31/14 10:56 AM
05/31/14 10:56 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Almost any vacuum leak will cause a problem.
Air bleed location.
Re: SURGING Six Pack carbs [Re: srt] #310208
05/31/14 11:08 AM
05/31/14 11:08 AM
mopar346 Offline
mopar346  Offline
Not that I can tell, the only other test I could do is to take it on one of the back roads and cap off the booster post and see if it makes a difference. Have sprayed the intake a number times with no signs of a leak, it could be internal but it shows no signs of sucking oil.
Re: SURGING Six Pack carbs [Re: 62maxwgn] #310209
05/31/14 11:11 AM
05/31/14 11:11 AM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
right, while I'm checking in mid-stream, just wondering if sorting the carbs is chasing a symptom rather than the cause.
I noticed op's other post of the sooted-up/white insulator plugs.
Got me to thinking that a vacuum leak down-stream of the carbs may need investigated. i.e. a split booster diaphragm that opens up under high vacuum only.
Re: SURGING Six Pack carbs [Re: 62maxwgn] #310210
05/31/14 11:19 AM
05/31/14 11:19 AM
mopar346 Offline
mopar346  Offline
I'll cover the bleeds today and make sure the pod to body seal is holding later. Using the sight glass, I set it to just be visible, afterwardds when I removed the sight glass to put the plug back in it didn't dump a lot of fuel like one that is set high either. The base float set up I have always heard and used on a center pivot you set the top of the float parallel to the top of the bowl and then adjust on the car running. In the picture my bowl isn't close to parallel.
I will definitely give you this, mine don't look nearly that good, not to get your trade secret but do you recoat the carbs or is that some brand of carb paint?
Re: SURGING Six Pack carbs [Re: mopar346] #310211
05/31/14 01:34 PM
05/31/14 01:34 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Set the fuel level with the engine running, for starters bring the fuel level up to the bottom of the site plug hole, I too like to use the clear site plugs, as I bring the center carb fuel height up to the center of the window, for street use just at the bottom of the site plug is fine, if your going to throw the car around a road course/track event, then that's when I bring the fuel level up to the middle of the site plug on all 3 carbs"new" Holley clear site plugs suck!, as you found out earlier, they just dissolve with fuel and soften up, the Moroso clear site plugs I have heard from another member are much better if you want to keep them in, all my six pack cars run clear site plugs, fortunately I bought a number of them years ago, but a recent set (Holley) I bought for a 4bbl application lasted like 1 day before the suckers snapped off!
Anyway here's a closer pic of the air bleeds mentioned earlier (not a six pack carb, but still a Holley for reference)
Mike)
Re: SURGING Six Pack carbs [Re: DAYCLONA] #310212
05/31/14 11:46 PM
05/31/14 11:46 PM
mopar346 Offline
mopar346  Offline
Yep, I found the air bleed and had a slight leak in the front one, pulled the pod off and the o-ring appeared pinched, I replaced it and then they both had when I put vacuum to them. It wasn't enough of a leak to keep it from working and I cant image it would have caused a running issue since the air bleed is a built in leak in that circuit. I replaced the jets with 66s today and it pretty much cured the surge, I think I might feel it slightly but I may also be convincing myself of that. It doesn't appear to be running too rich from the plug readings I am pulled and from what my eyes and noise tell me, so that much is good. It was hard to start after the replacement and ran like cr@p until it was warm, doesn't stall but idled a 12-1300 RPMs, the hot restarts are not terrible but definitely spins longer than normal before it fires. I am going try to adjust everything out tomorrow if I can with the 66s. I'd rather it run a little rich and not worry about leaning the engine out on my trip. The hot start I can live with but the ragged running on cold start up might make me go back to 64s and live with the surge.
Dayclona, does the float level like high to you in the above pictures? I have more on this but I will hold it until you add your opinion, so I don't taint your thinking.
Re: SURGING Six Pack carbs [Re: mopar346] #310213
06/01/14 03:13 AM
06/01/14 03:13 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
When warm it idles at 1200-1300?
If so, something is still VERY wrong with the idle set up on the engine.
Re: SURGING Six Pack carbs [Re: mopar346] #310214
06/01/14 10:50 AM
06/01/14 10:50 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
not sue if this matters, just trying to help with ideas. what is your manifold vac and what power valve are you using?
Re: SURGING Six Pack carbs [Re: RobX4406] #310215
06/01/14 11:37 AM
06/01/14 11:37 AM
mopar346 Offline
mopar346  Offline
I kinda agree, but it doesn't have an idea issue with 64s, or anything else for that matter just the surge.
