Dana 60 #3101179
12/10/22 11:11 PM
12/10/22 11:11 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Will be installing a Dana 60 in a 70 Challenger with a 4 speed. Will be either a Moser Dana 60 or the Strange S60. Of the two rear ends, which one more resembles the original Mopar Dana 60? Which is the better of the two? Thanks.
Re: Dana 60 [Re: RROD] #3101181
12/10/22 11:17 PM
12/10/22 11:17 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
They both look pretty much the same but I like the S60 better from a service standpoint because gear changes are easier twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Dana 60 [Re: fourgearsavoy] #3101224
12/11/22 08:42 AM
12/11/22 08:42 AM
Missouri
70X Offline
70X  Offline
Missouri
Spring for a real one
Re: Dana 60 [Re: 70X] #3101243
12/11/22 11:05 AM
12/11/22 11:05 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
wave Yup , Call Doctor Diff .com , and ask Cass to build you a nice Factory looking Dana , that's New , and Better than factory ! XmasPengs NOW , Which Sure-Grip are You going to Choose & install ? bump
Re: Dana 60 [Re: 1969ronnie] #3101262
12/11/22 11:59 AM
12/11/22 11:59 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Mopar used "Dana" parts to build them. You can get one out of a scrap yard and have it made to your specs.
link
Re: Dana 60 [Re: RROD] #3101263
12/11/22 12:07 PM
12/11/22 12:07 PM
central il.
second 70 Offline
second 70  Offline
central il.
Here's a S 60 and the factory dana it replaced. Dr. Diff said it can handle 1000 HP were he said the track loc it replaced was only safe for about 400. The old one was a 71 B body dana which are the longest made for mopar and are rare. I sold it to a member for his 71 hemi charger and used the money to buy what Cass suggested. It's wonderful on the street. Under the car I don't think anyone would notice the difference.
Re: Dana 60 [Re: Moparite] #3101265
12/11/22 12:10 PM
12/11/22 12:10 PM
Alberta
rustbuckett68 Offline
Alberta
Don't forget that some Sweptline 1/2 tons also had Dana 60 diff, if ordered with sure grip. These had 5 on 4 1/2" axles, not sure on the width. F100's from
~64 t0 72 also had them as an option. Put one under my 66 after hurting 3 9" diffs. About 30 years ago, saw a 68 D100 with a /6, 4 speed with a Dana 4:88.
That would be fun up to 30 MPH.
Re: Dana 60 [Re: rustbuckett68] #3101300
12/11/22 01:42 PM
12/11/22 01:42 PM
N
NITROUSN Offline
NITROUSN  Offline
N
And what sweptline trucks would these be? I believe you are confused and calling a 9 1/4 a Dana.
Re: Dana 60 [Re: NITROUSN] #3101400
12/11/22 07:31 PM
12/11/22 07:31 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Thanks for the pictures. Subtle difference between the housings. I’ll give Dr. Diff a call. The problem I have with the truck Dana is the lack of the mounting boss for the pinion snubber. I have time to search for an original Dana 60 but they are hard to find.
Re: Dana 60 [Re: RROD] #3101449
12/11/22 09:58 PM
12/11/22 09:58 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Another vote for Cass (Dr Diff). He always does a great job with his products. Too bad he don’t come out to the Spring Fling in CA anymore. He always had good stuff and I’m kinda cheap for forking out for shipping. 🤣
Re: Dana 60 [Re: RROD] #3101614
12/12/22 02:55 PM
12/12/22 02:55 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
If using a stock style cover, there's really not much different looking on either the Strange S60 or the Moser M60. Unless you crawled under the car and got your face right up to it, I don't think you'd notice anything.
I'd go w/ the Strange S60 simply b/c it has the side adjusters that makes life much easier when setting up the gear. The Moser M60 doesn't have that, but is still a great rear. I've had an M60 under my cuda since 2003 or 2004. up
CHIP
'06 GMC 2500HD LBZ Duramax
