Mini starter question #3101081
12/10/22 01:56 PM
12/10/22 01:56 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
While I have the engine out I'm going to go with a mini starter. I know a 96 Ram, Dakota starter will work, I have also read that an 05-08 Ram manual trans Hemi starter will, they are smaller. Will these work? Thoughts.
America First!
Re: Mini starter question [Re: carnut68] #3101099
12/10/22 04:01 PM
12/10/22 04:01 PM
moparx Online content
moparx  Online Content
i have been thinking about that manual starter being smaller as well.
however, i'm like you.
it would be nice if someone could show [side by side if possible] the size difference between the two, then we would know for certain.
it could also point out design differences [?] that may interfere [?] with other items such as header clearance to the starter cables.
beer
Re: Mini starter question [Re: moparx] #3101103
12/10/22 04:24 PM
12/10/22 04:24 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have a factory Dakota starter on my Savoy. Not sure what year it is but I put new contacts in it 16 years ago before I installed. It is one of the few starters that will fit with a 143 tooth flywheel and a steel bell. It may even be from a V6 because it's pretty small but it starts my 493 even on 90 degree days.
I can't stress enough that you buy a real Denso unit made in Detroit or Japan. Stay away from the many Chinese copies at the parts stores because they are hit or miss for quality. Mancini Racing sells the real thing but be prepared to spend twice as much money. You can also get a Denso re-man that is like a brand new one.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Mini starter question [Re: fourgearsavoy] #3101104
12/10/22 04:27 PM
12/10/22 04:27 PM
BDW Offline
BDW  Offline
I'm using the 05 starter, but it's a 5.7 with 518
Thing I don't like is the power stud, comes 90 deg, compared to straight up for the old mini
https://board.moparts.org/ubbthread...adapter-lug-for-starter.html#Post3070253
Re: Mini starter question [Re: BDW] #3101131
12/10/22 06:39 PM
12/10/22 06:39 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Here are photos from Rockauto - I can't see any obvious size difference. Top is '05 Ram manual trans. Bottom is '95 Dakota
Re: Mini starter question [Re: Stanton] #3101152
12/10/22 07:53 PM
12/10/22 07:53 PM
BDW Offline
BDW  Offline
It's definitely smaller, will take some pics, when I can find the old mini
Re: Mini starter question [Re: BDW] #3101189
12/10/22 11:41 PM
12/10/22 11:41 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Based on the photos I don’t see anything smaller. If you compare the snout sizes in each photo they’re virtually identical meaning the scale of each photo is pretty damn close and so are the complete motors. Exactly “what” part is smaller?
Let’s see your photos.
Re: Mini starter question [Re: Stanton] #3101219
12/11/22 06:37 AM
12/11/22 06:37 AM
BDW Offline
BDW  Offline
This is a 05 starter, your top pic is wrong
Re: Mini starter question [Re: BDW] #3101229
12/11/22 09:50 AM
12/11/22 09:50 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
I'm thinking that would work, even if you have drill threads out of the mount holes.
America First!
Re: Mini starter question [Re: carnut68] #3101232
12/11/22 10:01 AM
12/11/22 10:01 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Thanks, I picked the wrong engine option when I looked on Rockauto. So is that solenoid a replaceable item - sold separately?
Re: Mini starter question [Re: Stanton] #3101235
12/11/22 10:12 AM
12/11/22 10:12 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
Looking at the R A website it looks like it is.
America First!
Re: Mini starter question [Re: carnut68] #3101312
12/11/22 02:14 PM
12/11/22 02:14 PM
so the common mini starter is [looks like] a gear reduction style, while the smaller one is direct drive ? shruggy
beer
Re: Mini starter question [Re: moparx] #3101340
12/11/22 03:38 PM
12/11/22 03:38 PM
BDW Offline
BDW  Offline
05 is narrow, but taller
Re: Mini starter question [Re: moparx] #3101362
12/11/22 05:07 PM
12/11/22 05:07 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
beer
Betting the smaller straight one has an internal gear reduction, like a planetary in an automatic transmission.
Re: Mini starter question [Re: John Brown] #3101368
12/11/22 05:27 PM
12/11/22 05:27 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'm guessing no performance advantage, just fitment. Both probably have the same torque rating.
Re: Mini starter question [Re: Stanton] #3101384
12/11/22 06:52 PM
12/11/22 06:52 PM
BDW Offline
BDW  Offline
https://www.motortrend.com/how-to/ccrp-1207-lightweight-pmgr-starters-junkyard-builder/
The first Chrysler gear reduction starters used offset gears that added width. The advantage to late-model PMGR starters is the planetary gear-reduction system that multiplies torque while being entirely in line with the armature shaft. Planetary gear multiplication (similar to gear reduction in automatic transmissions) produces a major torque increase within a very small envelope.
Re: Mini starter question [Re: Stanton] #3101425
12/11/22 08:42 PM
12/11/22 08:42 PM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
That's what I'm looking for, it's smaller. I would like to see one mounted b/4 I buy one. It looks like it might work.
America First!
Re: Mini starter question [Re: carnut68] #3101432
12/11/22 08:56 PM
12/11/22 08:56 PM
BDW Offline
BDW  Offline
Do a search, within the last 2 months this came up, the guy thought it wouldn't work with BB.
I'll say same thing here, as I did in that other post.
Buy it on Amazon, free delivery, if it doesn't fit, free returns, $85
Re: Mini starter question [Re: BDW] #3101439
12/11/22 09:08 PM
12/11/22 09:08 PM
Cab_Burge Online work
Cab_Burge  Online Work
I am not a big internet auto parts shopper, that being said I have never bought any auto parts from Amazon or Rock Auto, how is the quality of the parts they sell?
I have bought some cheaper Chineze hard part years ago and recently some SB Mopar aluminum Speed Master heads from Pro Form, but I haven't taken them out of their boxes yet to look at them realcrazy
What say you guys on this help
Thanks in advance up
Re: Mini starter question [Re: BDW] #3101488
12/12/22 12:03 AM
12/12/22 12:03 AM
Md.
carnut68 Offline OP
carnut68  Offline OP
Md.
So I see you are using one. My problem is the starter has to be mounted b/4 the engine goes in. Abody w/TTi chassis headers. So it's not that easy. I remember reading that thread, that's where I got the idea.
America First!
