Re: How to Repair Light Windshield Scratches
[Re: Powerflow]
#3100884
12/09/22 01:37 PM
12/09/22 01:37 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
You can try but pretty sure you are going to create a wave form in the glass that may be more egregious than the scratch.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Powerflow]
#3100950
12/09/22 07:59 PM
12/09/22 07:59 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Cerium oxide.
Several tutorials on youtube
Tooth paste and similars works on plastic, not on glass
[Re: NachoRT74]
#3100968
12/09/22 08:56 PM
12/09/22 08:56 PM
Posts: 5,886 ohio
ruderunner
ohio
Long straight strokes. DO NOT CONCENTRATE ON THE SCRATCH ITSELF. You basically sand the entire window down to meet the scratch.
But, it sounds like yours are pretty deep.
For very minor scratches I use Fast Orange and a rubber block.
If you can get the epoxy thats used for chips, you can carefully mask the scratch, build up the epoxy, then shave and sand it .
Angry white pureblood male
[Re: Powerflow]
#3101054
12/10/22 12:06 PM
12/10/22 12:06 PM
Posts: 15,429 Omaha Ne
TJP
Omaha Ne
Would rubbing with 'XXXX' steel wool with WD-40 as a lube have any affect? Doubtful and it might cause yet another problem with getting the WD off . there are several "kits" on AMZ that have good reviews, most are for chips but some do claim to do scratches AMZ LINKYput " windshield scratch repair" in the search box, read the reviews, and roll the dice might check on the cost of a replacement windshield, pre Biden they sometimes were quite affordable post back if you find a solution
