How to Repair Light Windshield Scratches #3100834
12/09/22 11:08 AM
12/09/22 11:08 AM
New Jersey
P
Powerflow Offline OP
P
New Jersey
I have an old squeegee in my daily driver that has a good rubber blade on one side and a metal edge on the other (left over from a plastic scraper edge that broke). I was in a hurry this morning and started using the metal edge, which made some light scratches in the windshield glass about 6" long. They're right in my line of sight and visible if the light is right. Most of it doesn't catch my fingernail but one or two small sections do. Is there anything mild I can use to try to lighten the scratches? I've heard of using Bon Ami or toothpaste. Are there any other home remedies to try?
Re: How to Repair Light Windshield Scratches [Re: Powerflow] #3100884
12/09/22 01:37 PM
12/09/22 01:37 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
You can try but pretty sure you are going to create a wave form in the glass that may be more egregious than the scratch. twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: How to Repair Light Windshield Scratches [Re: W.I.N. Racing] #3100935
12/09/22 05:37 PM
12/09/22 05:37 PM
New Jersey
P
P
New Jersey
That's what I'm concerned about. I want to try the least aggressive method and live with the results. It's just a matter of finding the right procedure for a one-and-done attempt.
Re: How to Repair Light Windshield Scratches [Re: Powerflow] #3100950
12/09/22 07:59 PM
12/09/22 07:59 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Cerium oxide.
Several tutorials on youtube
Tooth paste and similars works on plastic, not on glass
Re: How to Repair Light Windshield Scratches [Re: NachoRT74] #3100968
12/09/22 08:56 PM
12/09/22 08:56 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Long straight strokes. DO NOT CONCENTRATE ON THE SCRATCH ITSELF. You basically sand the entire window down to meet the scratch.
But, it sounds like yours are pretty deep.
For very minor scratches I use Fast Orange and a rubber block.
If you can get the epoxy thats used for chips, you can carefully mask the scratch, build up the epoxy, then shave and sand it .
Angry white pureblood male
Re: How to Repair Light Windshield Scratches [Re: ruderunner] #3101028
12/10/22 08:44 AM
12/10/22 08:44 AM
New Jersey
P
P
New Jersey
Would rubbing with 'XXXX' steel wool with WD-40 as a lube have any affect?
Re: How to Repair Light Windshield Scratches [Re: Powerflow] #3101054
12/10/22 12:06 PM
12/10/22 12:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Doubtful and it might cause yet another problem with getting the WD off shruggy .
there are several "kits" on AMZ that have good reviews, most are for chips but some do claim to do scratches AMZ LINKY
put " windshield scratch repair" in the search box, read the reviews, and roll the dice wink
might check on the cost of a replacement windshield, pre Biden they sometimes were quite affordable wink
post back if you find a solution beer
Re: How to Repair Light Windshield Scratches [Re: Powerflow] #3101055
12/10/22 12:08 PM
12/10/22 12:08 PM
CrazyD Offline
CrazyD  Offline
If the scratches interfere with your line of sight, perhaps your car insurance would replace the windshield as part of comprehensive coverage.
Re: How to Repair Light Windshield Scratches [Re: CrazyD] #3101191
12/10/22 11:45 PM
12/10/22 11:45 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
Barkeepers Friend
Link
Re: How to Repair Light Windshield Scratches [Re: nuthinbutmopar] #3101485
12/11/22 11:39 PM
12/11/22 11:39 PM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
Look on ebay "windshield scratch repair" .I hav used cerium oxide on light scratches. Takes time. I have never tried sand paper first that some of these kits have.
