Re: Was anyone here part of the 2015 Drag pak program?
[Re: biff426]
#3100749
12/08/22 09:58 PM
12/08/22 09:58 PM
Posts: 1,142 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Wooooooooooooooooooooooooooooooooooooooo Hooooooooooooooooooooooooooooooooooooooo !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I over Drag Paks Edit: Have you been on classracer.com and tried to find any sources of info there? Perhaps you can contact the Direction Connection people about documentation they provide w/ the new Drag Paks? Edit #2 - Maybe some info here? https://www.dodgegarage.com/drag-pak-experience/startup-proceduresThere are a bunch of other links accessible from that page, too.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: biff426]
#3100830
12/09/22 10:53 AM
12/09/22 10:53 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Obviously, Ray or David Barton can explain those to you. I do love those. They b bad.
2011 Drag Pak Challenger
[Re: rickseeman]
#3100843
12/09/22 11:46 AM
12/09/22 11:46 AM
Posts: 1,552 Michigan
Kiddart
if you are up for it what does something like this run nowadays? price wise?
Thank you Kiddart
[Re: biff426]
#3100848
12/09/22 12:01 PM
12/09/22 12:01 PM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
I was out in fall 2013, mostly thanks to an excellent-turned-to-trash contract house, so I only know what I know. My Team's efforts towards some kind of an information package is represented Here, which is a link to a document that was originally delivered with the car. But....the older "You finish it" Drag Pak is so far removed from a 2015, I'd have to throw that whole thing away and assume nothing applies. It's hard to imagine that expensive of a product being delivered without any info, but it is Mopar after all..... I know a Mopar retired program mgr, and a Roush manager who moved on to Ford contract work, then went back to Roush....not sure if he has his old records. I can ask those guys, if that'd help? Not sure if they would remember or know anyone. Alot of people have left the company/companies involved since 2015-16 and a search could be difficult.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3100857
12/09/22 12:19 PM
12/09/22 12:19 PM
Posts: 3,517 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I would think that DSR Performance ( https://dsrperformance.com/) should be able to tell you anything you need to know. While I don't know him Geoff Turk seems like a generous and very approachable guy. You probably can reach him via Facebook. As long as you did not make yourself a pest I bet he would give you some direction.
[Re: ZIPPY]
#3100859
12/09/22 12:21 PM
12/09/22 12:21 PM
rickseeman
Stuttgart, Arkansas
I got a "owners manual" for my 2011 a year after I got the car.
[Re: 340Cuda]
#3100861
12/09/22 12:22 PM
12/09/22 12:22 PM
rickseeman
Stuttgart, Arkansas
I would think that DSR Performance ( https://dsrperformance.com/) should be able to tell you anything you need to know. While I don't know him Geoff Turk seems like a generous and very approachable guy. You probably can reach him via Facebook. As long as you did not make yourself a pest I bet he would give you some direction. I believe DSR is where you have to get the parts. And they know the cars.
[Re: rickseeman]
#3100876
12/09/22 01:18 PM
12/09/22 01:18 PM
ZIPPY
S.E. Michigan
I got a "owners manual" for my 2011 a year after I got the car. Sorry man, it was supposed to be delivered with the car, it is Mopar after all.....
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3100888
12/09/22 02:01 PM
12/09/22 02:01 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Maybe try reaching out to some of the NMCA racers as well who run the factory shootout classes. For engines Barton and BES do them. Unfortunately there are nowhere near as many FSS Mopar guys as the other makes for sure. Also maybe look in your area for someone running NHRA Stk or SS, try some place like Classracer.com
[Re: biff426]
#3100901
12/09/22 02:35 PM
12/09/22 02:35 PM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
Geoff Turk is at PRI with the new Factory X car this weekend. He's easy enough to find on Facebook and is a really good guy.
