Re: Piston to valve clearance question
[Re: 6PAX]
#3100540
12/07/22 10:40 PM
12/07/22 10:40 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
[Re: 6PAX]
#3100548
12/07/22 11:12 PM
12/07/22 11:12 PM
Posts: 711 California
BigDaddy440
California
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: 6PAX]
#3100573
12/08/22 08:40 AM
12/08/22 08:40 AM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
The specs are misleading; the 1009 is questionable IMO on anything larger than 4.350. I've used them on 4.375", but my cylinders had absolutely no chamfer at the top that let the gasket overhang into the bores. Others haven't been so lucky and the torched gasket between cylinders is the result. FWIW, the Fel-Pro marine gasket (17059?) has a true 4.500" bore and may be a better choice.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3100625
12/08/22 12:27 PM
12/08/22 12:27 PM
Posts: 4,737 Moved to N.E. Tennessee
GomangoCuda
As Brad mentioned it's not the bore size that's important it's the bore chamfer size. Some have a chamfer that is big enough for the gasket to hang out. If the chamfer O.D. is bigger than the gasket I.D. then the gasket will burn and damage the block and head.
[Re: GomangoCuda]
#3100629
12/08/22 12:44 PM
12/08/22 12:44 PM
Posts: 5,642 Detroit area
6PAX
Detroit area
I guess I'm going to have to pull the heads back off and check as we put them on the motor about 3 years ago. The engine still hasn't been run and it is still on the stand. Being the engine hasn't been run, will the gaskets still be O.K. to use if the gasket is not intefering with the cylinder bore?
[Re: 6PAX]
#3100630
12/08/22 12:46 PM
12/08/22 12:46 PM
Brad_Haak
Loudoun County, VA
I guess I'm going to have to pull the heads back off and check as we put them on the motor about 3 years ago. The engine still hasn't been run and it is still on the stand. Being the engine hasn't been run, will the gaskets still be O.K. to use if the gasket is not into with the cylinder bore? Yes
[Re: GomangoCuda]
#3100648
12/08/22 01:47 PM
12/08/22 01:47 PM
Posts: 277 MN
Willie68coronet
MN
As Brad mentioned it's not the bore size that's important it's the bore chamfer size. Some have a chamfer that is big enough for the gasket to hang out. If the chamfer O.D. is bigger than the gasket I.D. then the gasket will burn and damage the block and head. Yep. I have a 400 block that's bored to 4.375. I had to return Cometic's with a 4.410 I.D. The gaskets looked good on TFS 270's. But overhung the chamfer on the block just enough enough in most or all cylinders, that I exchanged them for the 4.5 bore gaskets.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
