Trick flow intake vs Torker 2
#3100372
12/07/22 12:03 PM
12/07/22 12:03 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Howdy - long time no see. Still have my 72 Challenger w 505, Trickflow 240 heads, Comp Solid FT 248 at 50 and Torker 2 intake, 1 7/8 headers, 3" exhaust, 4speed w 3.55's. Thinking of swapping intakes. Im sure the Trick flow intake has to be worth some ponies up top, but also want to retain the factory rallye hood. What are your thoughts on this swap? Why did I wait so long, or not worth it for a car that wont see much track time and it may not even fit under the hood with an aircleaner? Ive had it to the track once just to run through the gears. One soft launch pass and 12.50 at 116mph.
2 kids and a dog
Re: Trick flow intake vs Torker 2
[Re: TonyS451]
#3100401
12/07/22 01:18 PM
12/07/22 01:18 PM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Yes, the TF intake is going to be worth some HP over a Torker 2. But... I don't know if it'll fit under a stock R/T or Rallye hood with any reasonable size air cleaner. If it does, it's gotta be a pretty tight fit.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3100420
12/07/22 02:31 PM
12/07/22 02:31 PM
Posts: 16,928 NC
440Jim
NC
Manifold heights from each manf website: Track Heat®intake manifold (part number TFS-61600113) Intake Manifold Height: 6.250 in. Trick Flow LINKEdelbrock Torker II intake manifold 5091. Edelbrock LINKFront Maximum Height 4.150 in Center Maximum Height 4.670 in Rear Maximum Height 5.200 in
[Re: 440Jim]
#3100444
12/07/22 03:23 PM
12/07/22 03:23 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Keep in mind the Ede manifold has the carb pad angled so the carb is basically level in a normal car, and the TF intake is not, so the carb would be parallel to the pan rail. This reduces air cleaner clearance towards the front.
[Re: fast68plymouth]
#3100462
12/07/22 04:25 PM
12/07/22 04:25 PM
TonyS451
Chicago, IL
Thanks for the feedback and dimensions. Yeah Im sure it will be super tight fit. Was hoping someone has done this already with proof that it all fits with this or that air cleaner...
2 kids and a dog
[Re: TonyS451]
#3100463
12/07/22 04:27 PM
12/07/22 04:27 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
[Re: TonyS451]
#3100475
12/07/22 05:18 PM
12/07/22 05:18 PM
Brad_Haak
Loudoun County, VA
I was going to suggest an AAR Fiberglass T/A replica hood, but that's just me...
[Re: Brad_Haak]
#3100478
12/07/22 05:34 PM
12/07/22 05:34 PM
fast68plymouth
So. Burlington, Vt.
Brad went for the “other” R/T hood....... as in “Real Tall”
#3100479
12/07/22 05:43 PM
12/07/22 05:43 PM
Brad_Haak
Loudoun County, VA
Brad went for the “other” R/T hood....... as in “Real Tall” Yep, it's an R/T T/A!
#3100482
12/07/22 05:48 PM
12/07/22 05:48 PM
an8sec70cuda
Brad went for the “other” R/T hood....... as in “Real Tall” LOL! Brad...you seem like you're kinda on the fence about your hood...not that my opinion matters, but I like it!
#3100521
12/07/22 08:47 PM
12/07/22 08:47 PM
TonyS451
Chicago, IL
Brad went for the “other” R/T hood....... as in “Real Tall” r lol
2 kids and a dog
[Re: TonyS451]
#3100569
12/08/22 08:22 AM
12/08/22 08:22 AM
Brad_Haak
Loudoun County, VA
Tony - a standard T/A replica hood was tall enough to let me run Stage VI heads (raised ports), a Victor intake (comparable height to TF) and a 3" drop-base air cleaner. Probably another 1/2" clearance w/ standard-location intake ports; no room for spacers or taller air cleaner w/ the Stage VIs (very tight fit).
[Re: Brad_Haak]
#3100570
12/08/22 08:28 AM
12/08/22 08:28 AM
Brad_Haak
Loudoun County, VA
But if you wanna have room for raised ports, spacers, and taller air cleaners,
[Re: Brad_Haak]
#3100575
12/08/22 09:10 AM
12/08/22 09:10 AM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
Tony - a standard T/A replica hood was tall enough to let me run Stage VI heads (raised ports), a Victor intake (comparable height to TF) and a 3" drop-base air cleaner. Probably another 1/2" clearance w/ standard-location intake ports; no room for spacers or taller air cleaner w/ the Stage VIs (very tight fit). beautiful car
[Re: Brad_Haak]
#3100579
12/08/22 09:46 AM
12/08/22 09:46 AM
TonyS451
Chicago, IL
Tony - a standard T/A replica hood was tall enough to let me run Stage VI heads (raised ports), a Victor intake (comparable height to TF) and a 3" drop-base air cleaner. Probably another 1/2" clearance w/ standard-location intake ports; no room for spacers or taller air cleaner w/ the Stage VIs (very tight fit). I like that hood a bit more than the T/A on steroids hood, but I can understand why . Glad to see you're back, Brad. Last I was here I think you were taking a vacation. You always have good info to offer. Btw, the 950 carb I bought from you is still running great. I dont think I've touched a screw in 2 years
2 kids and a dog
[Re: TonyS451]
#3100631
12/08/22 12:47 PM
12/08/22 12:47 PM
Brad_Haak
Loudoun County, VA
