Re: Alum block head studs?
[Re: RATTRAP]
#3099743
12/05/22 10:28 AM
12/05/22 10:28 AM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Dry, finger tight (or slight interference fit) is the way I always do it.
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#3099754
12/05/22 11:03 AM
12/05/22 11:03 AM
Posts: 2,915 A shed in England
Tig
A shed in England
I always use a little motor oil so they come back out easier, being dissimilar metals they can suffer from galvanic corrosion. I have lots of used studs that have the "pitting" marks on them that bares witness to that. I hear using an earth strap, connecting block and head, can help with this so it's what I do.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: RATTRAP]
#3099792
12/05/22 12:46 PM
12/05/22 12:46 PM
Posts: 31,002 Oregon
AndyF
Install studs Dry, ARP Lube, or Anti-Seize. ARP lube finger tight and back off from the bottom a quarter turn
[Re: HardcoreB]
#3099826
12/05/22 02:33 PM
12/05/22 02:33 PM
Posts: 16,923 NC
440Jim
NC
When does the stud stop turning into the tapped hole? Back in 2014 when I bought a KB aluminum block, they supplied the heads studs (for my 440-1 heads) with the block. They have ARP make the studs with a stand off end (0.130" long) to bottom the stud in the hole, and not by the threads. They also have the ARP "quick start" feature for the nuts on the head side. I wish all the aluminum blocks were supplied this way.
[Re: 440Jim]
#3099832
12/05/22 02:41 PM
12/05/22 02:41 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
When does the stud stop turning into the tapped hole? Back in 2014 when I bought a KB aluminum block, they supplied the heads studs (for my 440-1 heads) with the block. They have ARP make the studs with a stand off end (0.130" long) to bottom the stud in the hole, and not by the threads. They also have the ARP "quick start" feature for the nuts on the head side. I wish all the aluminum blocks were supplied this way. Thats how mine are that came with my KB block, I just did not get the inner studs with the block.
[Re: HardcoreB]
#3099843
12/05/22 03:33 PM
12/05/22 03:33 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I used that method after I seen MrPbody post that tip with small ball bearings Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
