spark plug tubes stage v cover #3099200
12/03/22 01:33 PM
12/03/22 01:33 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Can anyone tell me what tubes and hardware i need for the stage v valve cover?
Re: spark plug tubes stage v cover [Re: mopar dave] #3099225
12/03/22 03:04 PM
12/03/22 03:04 PM
Cab_Burge Online work
Cab_Burge  Online Work
Try Tim at FHO 905-797-2459 or Stage V at 909-595-8383 scope up
Re: spark plug tubes stage v cover [Re: Cab_Burge] #3099234
12/03/22 03:20 PM
12/03/22 03:20 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Same as stock
2011 Drag Pak Challenger
Re: spark plug tubes stage v cover [Re: rickseeman] #3099423
12/04/22 10:40 AM
12/04/22 10:40 AM
Mt Morris Michigan
Mt Morris Michigan
I thought the stage V cover was taller than stock cover?
Re: spark plug tubes stage v cover [Re: Cab_Burge] #3099425
12/04/22 10:42 AM
12/04/22 10:42 AM
Mt Morris Michigan
Mt Morris Michigan
I will not be contacting Tim for anything for this point. I may give stage v a call, but i had trouble getting them to answer the phone in the past.
Re: spark plug tubes stage v cover [Re: mopar dave] #3099450
12/04/22 12:06 PM
12/04/22 12:06 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I don't think Stage V sells plug tubes and o-rings.
Re: spark plug tubes stage v cover [Re: rickseeman] #3099455
12/04/22 12:18 PM
12/04/22 12:18 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
By the way Stage V valve covers take STOCK o-rings. NOTICE I SAID STOCK IN CAPS. This means stock. Not this garbage that Mopar has been selling us for 30 years. The only place I've found those in the last 20 years has been John Arruzza. Is he back?
Re: spark plug tubes stage v cover [Re: rickseeman] #3099458
12/04/22 12:26 PM
12/04/22 12:26 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
You said hardware. If it's studs you're looking for, those are ARP 245-7601 for KB valve covers.
Re: spark plug tubes stage v cover [Re: mopar dave] #3099467
12/04/22 12:43 PM
12/04/22 12:43 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Kinda sorta. But the depth of the recess for the plug tube is .200" deeper. What this means is that the stock tubes work but they won't have that lip sticking up over the top of the valve cover to align the stock street hemi plug covers.
Re: spark plug tubes stage v cover [Re: rickseeman] #3099509
12/04/22 02:28 PM
12/04/22 02:28 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I should say the Stage V valve covers are taller/wider down lower where it matters with some rockers. Ray Barton rockers and some others don't fit under stock valve covers but they will under KB, Stage V and Ansen.
Re: spark plug tubes stage v cover [Re: rickseeman] #3099655
12/04/22 10:30 PM
12/04/22 10:30 PM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
https://www.facebook.com/rickshemis/ If Rick is still into things he will take care of you. Good guy IMO, had really good luck with him years ago.
Re: spark plug tubes stage v cover [Re: BryanRad] #3099665
12/04/22 11:21 PM
12/04/22 11:21 PM
Mt Morris Michigan
Mt Morris Michigan
Hey thanks guys. I found a set of OEM 426 tubes used.
