Transmission ID #3096969
11/25/22 09:20 AM
11/25/22 09:20 AM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Need to identify PK4058395 7778 532 , big block , small block , lockup or non lockup , thanks
Re: Transmission ID [Re: 426lloyd] #3096983
11/25/22 10:18 AM
11/25/22 10:18 AM
NY
twodoorpost Offline
twodoorpost  Offline
NY
4058395
Dodge Truck 1982-83 8·318 8 & 360 A727 D150, D250, & D350 4X2 Long extension
Dodge Truck 1982-83 8·318 8 & 360 A727 B150, B250, & B350 4X2 Long extension
Ramcharger 1682
Trail Duster 1982
Re: Transmission ID [Re: twodoorpost] #3097022
11/25/22 01:00 PM
11/25/22 01:00 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
Would a slant 6 , 727 have the same numbers
Re: Transmission ID [Re: 426lloyd] #3097025
11/25/22 01:16 PM
11/25/22 01:16 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Very doubtful as the front of the trans/bellhousing would be completely different beer
Re: Transmission ID [Re: TJP] #3097042
11/25/22 02:01 PM
11/25/22 02:01 PM
moparx Offline
moparx  Offline
most telling would be the high starter location the slanty requires.
beer
Re: Transmission ID [Re: 426lloyd] #3097704
11/28/22 09:58 AM
11/28/22 09:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No the bellhousing, which is part of the maincase casting, is totally different between the /6 and the small block .
Re: Transmission ID [Re: JohnRR] #3097777
11/28/22 01:28 PM
11/28/22 01:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The high-mounted starter makes the /6 easy to spot.
Re: Transmission ID [Re: John_Kunkel] #3097792
11/28/22 02:16 PM
11/28/22 02:16 PM
moparx Offline
moparx  Offline
note the starter location in the other two pictures JK supplied.
small block has starter at roughly the 4 o'clock position, while the big block starter is at 3 o'clock.
my easy way to tell them apart at a glance.
beer
