Engine dyno near Sacramento #3097071
11/25/22 03:22 PM
11/25/22 03:22 PM
Hangtowner Offline OP
Is there a Mopar friendly engine dyno shop near Sacramento? Really just looking for oil leaks on a fresh rebuild so I could modify my storage stand into a run stand as Plan B.
Re: Engine dyno near Sacramento [Re: Hangtowner] #3097105
11/25/22 06:41 PM
11/25/22 06:41 PM
AndyF Offline
AndyF  Offline
Putting an engine on a dyno and making a few pulls is going to cost you at least $1000 and probably closer to $2000 these days. That is a lot of money just to check for oil leaks.
Re: Engine dyno near Sacramento [Re: AndyF] #3097113
11/25/22 07:13 PM
11/25/22 07:13 PM
Washington
madscientist Offline
Washington
THIS^^^^^. Find a good dyno shop and learn things. You’d be surprised what you can find with some careful testing.
Re: Engine dyno near Sacramento [Re: AndyF] #3097114
11/25/22 07:13 PM
11/25/22 07:13 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I used Vintage Hot Rod in Chico Ca. It cost me $750 for as many pulls as I wanted. Great group of guys. They do not have a website, but are on Facebook …
https://www.facebook.com/VintageHotRod/
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Engine dyno near Sacramento [Re: BloFish] #3097115
11/25/22 07:16 PM
11/25/22 07:16 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Engine dyno near Sacramento [Re: BloFish] #3097316
11/26/22 04:35 PM
11/26/22 04:35 PM
I used them several years back up
Re: Engine dyno near Sacramento [Re: Cab_Burge] #3097597
11/27/22 06:15 PM
11/27/22 06:15 PM
Thanks, I will give Vintage Hot Rod a call. Its bit far, but I see modifying my storage stand won't work. I don't have any 4 speed stuff so would have to mount a 727 on the back for the starter provisions.
I might have to modify a friend's run stand that last had a 1275cc Mini Cooper engine on it.
Re: Engine dyno near Sacramento [Re: Hangtowner] #3097600
11/27/22 06:42 PM
11/27/22 06:42 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I guess it’s all perspective.......
Looks like Chico is about 1-1/2hrs from Sacto.
To me, that seems like a very reasonable drive to have access to a known decent test facility that’s set up to run the type of engine you need tested.
Re: Engine dyno near Sacramento [Re: fast68plymouth] #3097612
11/27/22 07:23 PM
11/27/22 07:23 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Worth the drive for sure.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
