Re: Engine dyno near Sacramento
[Re: AndyF]
#3097113
11/25/22 07:13 PM
11/25/22 07:13 PM
Posts: 4,457 Washington
madscientist
Washington
Putting an engine on a dyno and making a few pulls is going to cost you at least $1000 and probably closer to $2000 these days. That is a lot of money just to check for oil leaks. THIS^^^^^. Find a good dyno shop and learn things. You’d be surprised what you can find with some careful testing.
[Re: AndyF]
#3097114
11/25/22 07:13 PM
11/25/22 07:13 PM
Posts: 16,491 On the run…
BloFish
On the run…
I used Vintage Hot Rod in Chico Ca. It cost me $750 for as many pulls as I wanted. Great group of guys. They do not have a website, but are on Facebook … https://www.facebook.com/VintageHotRod/
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Hangtowner]
#3097600
11/27/22 06:42 PM
11/27/22 06:42 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I guess it’s all perspective.......
Looks like Chico is about 1-1/2hrs from Sacto.
To me, that seems like a very reasonable drive to have access to a known decent test facility that’s set up to run the type of engine you need tested.
[Re: fast68plymouth]
#3097612
11/27/22 07:23 PM
11/27/22 07:23 PM
BloFish
On the run…
Worth the drive for sure.
