Re: what rear main seal is best? [Re: feets] #3096450
11/23/22 01:03 AM
11/23/22 01:03 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
alot of good info here. gonna see if i can find the silicone adhesive tomorrow.
Re: what rear main seal is best? [Re: Cab_Burge] #3096836
11/24/22 02:37 PM
11/24/22 02:37 PM
Mt Morris Michigan
Mt Morris Michigan
Can, is this what you using?
Re: what rear main seal is best? [Re: mopar dave] #3096895
11/24/22 06:20 PM
11/24/22 06:20 PM
moparx Offline
moparx  Offline
looks like a similar product like the "rainbow" stuff i like to use.
i wouldn't be afraid to use the permatex stuff.
beer
Re: what rear main seal is best? [Re: moparx] #3096908
11/24/22 08:16 PM
11/24/22 08:16 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
This is what I use to glue the ends together. It looks just like red Loctite used on bolts but works great.
- Stu Harmon
Re: what rear main seal is best? [Re: mopar dave] #3096943
11/25/22 01:13 AM
11/25/22 01:13 AM
As long as it has "adhesive silicone" on it somewhere you should be good luck scope up
Not only silicone gasket maker down twocents
Re: what rear main seal is best? [Re: Cab_Burge] #3097198
11/26/22 09:19 AM
11/26/22 09:19 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
The one that says Top Fuel
Re: what rear main seal is best? [Re: FastmOp] #3097214
11/26/22 11:08 AM
11/26/22 11:08 AM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
https://www.fastfishautoparts.com/store/p_1203721/big-block-mopar-performance-rear-main-seal-
I am also dealing with the dreaded rear main seal leak. I was considering the fastfish one piece seal. Anyone ever use the one piece seal?
Re: what rear main seal is best? [Re: Harley] #3097244
11/26/22 12:44 PM
11/26/22 12:44 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I never realized there was such difference in the RTV gasket depending on the brand.
https://www.youtube.com/watch?v=ACIzlSanS60
It looks like the mopar and toyota name brands are amongst the best according to Project Farm.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: what rear main seal is best? [Re: Harley] #3097288
11/26/22 02:38 PM
11/26/22 02:38 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Yep Fast Fish is what I used on my build. Matt Hensley built LD 512 he had never used one before. He like it said probably use one on his SS HEMI. From run in stand to quite a few dyno pulls. No runs no drips no errors
Re: what rear main seal is best? [Re: HDNMOPERS] #3125910
03/02/23 01:44 PM
03/02/23 01:44 PM
Alabama
W
WarEagle1 Offline
WarEagle1  Offline
W
Alabama
Sorry to revive an older thread, but a quick question on side seals:
After the seal retainer is properly aligned and torqued in place, do you then force the RTV or silicone (from the tube) into the side seal area from the small opening at the pan rail surface? And then, per John K. and Mitch, insert a ~2 3/4" piece of damp pipe cleaner into the same opening?
Is the adhesive silicone preferred over RTV?
Thanks. I've only used the old cardboard or rubber side seals and wanted to try this method.
-Mike
Re: what rear main seal is best? [Re: WarEagle1] #3125930
03/02/23 02:58 PM
03/02/23 02:58 PM
Indiana
Gabby63 Online content
Gabby63  Online Content
Indiana
I use Ultra Grey Permatex , I also fill in the side grooves before sliding into position . Then you can run welding rod down into the side seal slot , refill then apply pan gasket . Have done this for stock seal retainer , billet retainer & also my Indy Max rear main & seal cap . Gary
