what rear main seal is best? #3095597
11/19/22 06:52 PM
11/19/22 06:52 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
What rear main seal you guys using lately. I need something for my BMP aluminum block.
Re: what rear main seal is best? [Re: mopar dave] #3095600
11/19/22 07:23 PM
11/19/22 07:23 PM
New York, USA
Chargerfan68 Offline
New York, USA
Is this race only and vacuum pump? Or street and gen use?
If race only and with a pump, i would recommend the multi piece seal from Tritek? (I think). They supply most if not all the nascar shops. Installed reverse for vacuum (lips pointing outside) it seals very well.
If street strip with no vacuum pump, I use the viton orange seal. The retainer is a whole other discusdion that you can find all over the net smile
Re: what rear main seal is best? [Re: Chargerfan68] #3095604
11/19/22 07:47 PM
11/19/22 07:47 PM
Mt Morris Michigan
Mt Morris Michigan
Mostly street deal, no vac pump. Thanks
Re: what rear main seal is best? [Re: mopar dave] #3095621
11/19/22 09:26 PM
11/19/22 09:26 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I run the orange Viton seal.
Measure where the lip of the seal aligns on the crank and adjust as necessary. Most leaks are from the two halves of the seal being out of alignment with one another.
- Stu Harmon
Re: what rear main seal is best? [Re: mopar dave] #3095675
11/20/22 02:46 AM
11/20/22 02:46 AM
Call SCE and get several Vitos from them up twocents wrench
661-728-9200 scope up
I seal all the side seal joints up completely with w good brand (I like and use Permatex now up) of adhesive silicone, NOT gasket maker tsk
Re: what rear main seal is best? [Re: Cab_Burge] #3095682
11/20/22 07:12 AM
11/20/22 07:12 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I bought one of the billet ones from Mancini and that pos leaked from day one. I then heard they need to have about .020 removed from the parting surface because they were made too tall. We removed it and measured. Sure enough. It was too tall. Put the stock one back and problem solved.
Re: what rear main seal is best? [Re: Cab_Burge] #3095724
11/20/22 10:56 AM
11/20/22 10:56 AM
Mt Morris Michigan
Mt Morris Michigan
Ok, so you dont use the side seals that come with the rear main seal? Would Right Stuff be ok to use on the sides of the retainer?
Re: what rear main seal is best? [Re: fastmark] #3095726
11/20/22 11:02 AM
11/20/22 11:02 AM
Mt Morris Michigan
Mt Morris Michigan
I used Mancini's billet rear seal kit on my 511 build. I clocked the seal to 12 and 6 o'clock as Monte had suggested. Didn't leak a drop the first season. It has a constant drip since. I want to be sure to get this correct this go around. Thanks guys
Re: what rear main seal is best? [Re: mopar dave] #3095808
11/20/22 03:19 PM
11/20/22 03:19 PM
moparx Offline
moparx  Offline
a gut reaction would be that if the engine wasn't occasionally turned over during the off season, maybe the seal slightly stuck to the crank, causing it to tear ever so slightly or deform a tiny bit, causing the leak ? shruggy
as to using the right stuff, i wouldn't use that myself.
as i think Cab [?] said, a clear silicone "adhesive" is the stuff to use.
"adhesive" needs to be on the label.
https://rainbowtech.net/wp-content/uploads/88000-Clear-RTV-Silicone.jpg
i like this stuff, but i'm sure there are other products out there that are like this.
beer
Re: what rear main seal is best? [Re: moparx] #3095817
11/20/22 03:52 PM
11/20/22 03:52 PM
Mt Morris Michigan
Mt Morris Michigan
OK, so use silicone adhesive and no side seals?
Re: what rear main seal is best? [Re: mopar dave] #3095819
11/20/22 04:01 PM
11/20/22 04:01 PM
moparx Offline
moparx  Offline
remember, i'm no engine builder.
however with that said, i have seen countless recommendations to fill the side areas with silicone "adhesive".
another tip to do with the rear seal retainer is drill out the bolt holes a size or two [depending on how the block threads are positioned and the seal retainer holes are drilled] to allow the retainer to center the seal on the crank, and thus the bolts can be tightened without moving the seal to one side or the other, causing the seal to be deformed.
beer
Re: what rear main seal is best? [Re: mopar dave] #3095834
11/20/22 05:01 PM
11/20/22 05:01 PM
No tsk Use the side seals and silicone them full (both sides of the rear main seal holder, drivers and passenger sides :wrench) from the crankshaft flywheel flange side, I use a thin narrow putty knife to fill them from the sides of the crank shaft flange wrench scope up
Re: what rear main seal is best? [Re: Cab_Burge] #3095846
11/20/22 06:20 PM
11/20/22 06:20 PM
Mt Morris Michigan
Mt Morris Michigan
ok, ill do that
Re: what rear main seal is best? [Re: mopar dave] #3095870
11/20/22 08:10 PM
11/20/22 08:10 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Align the seal retainer flush with the rear of the block, snug it down then look and see if the grooves line up.
Re: what rear main seal is best? [Re: mopar dave] #3095888
11/20/22 09:57 PM
11/20/22 09:57 PM
Arizona
Chucklehead Offline
Chucklehead  Offline
Arizona
I have used the one piece seal from Fast Fish Auto Parts. No leaks or sealing issues on a 470 stroker.
Still Broke
Re: what rear main seal is best? [Re: Chucklehead] #3095954
11/21/22 10:33 AM
11/21/22 10:33 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I fill the sides with rtv, then I shove a piece of precut 3/32 or 1/8 welding rod in there and it forces the rtv out slightly. I like seeing the expanded bead on retainer from top to bottom of the edge gap. Just my twist on this personal subject. I also put the seal in 12/6. And I wouldn't drill the holes seems that could add to the alignment issue. I have reduced the height slightly by flat sanding/milling approximately .010 off for a little extra crush. Most of the time its just the black rubber seal.
Re: what rear main seal is best? [Re: B1MAXX] #3096031
11/21/22 01:39 PM
11/21/22 01:39 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
A piece of pipe cleaner moistened with water works better, RTV cures by exposure to moisture.
Re: what rear main seal is best? [Re: John_Kunkel] #3096033
11/21/22 01:48 PM
11/21/22 01:48 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Dave , is this for your new block ? doesn't the rear main on the BM block incorporate the seal into the cap like the Indy block ? As far as a seal I use the black w/ orange stripe felpro seal I had left over from an old kit . No leaks in 2 years yet . Gary
Re: what rear main seal is best? [Re: John_Kunkel] #3096076
11/21/22 03:40 PM
11/21/22 03:40 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
A piece of pipe cleaner moistened with water works better, RTV cures by exposure to moisture.....
As Joe K indicates above... this is very critical... In fact, if you read the installation instructions from Fel-Pro sets, its exactly what they say... I wrote those instructions when I worked for Fel-Pro.[i][/i]
Re: what rear main seal is best? [Re: mopar dave] #3096352
11/22/22 04:04 PM
11/22/22 04:04 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I used the blue silicone side seals that came with the Viton main seal. The ends of the seals got a little red Permatex adhesive. It looks like Loctite not RTV.
If you drop the seal in the block then slide the retainer with seal in place you can look through the crank hole and see how the seals line up fore/aft. That will give you a good idea of what to do.
Other than that, you need to put a little oil/grease/assy lube on the crank and test fit the rear main. Give the crank a quarter turn or less and check the witness marks in the lube. You can see if the ends of the seal are lining up properly.
If they're not lined up perfectly then none of the above tricks will work. It will leak.
- Stu Harmon
