Re: what rear main seal is best?
[Re: mopar dave]
#3095600
11/19/22 07:23 PM
11/19/22 07:23 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Is this race only and vacuum pump? Or street and gen use? If race only and with a pump, i would recommend the multi piece seal from Tritek? (I think). They supply most if not all the nascar shops. Installed reverse for vacuum (lips pointing outside) it seals very well. If street strip with no vacuum pump, I use the viton orange seal. The retainer is a whole other discusdion that you can find all over the net
[Re: mopar dave]
#3095621
11/19/22 09:26 PM
11/19/22 09:26 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I run the orange Viton seal. Measure where the lip of the seal aligns on the crank and adjust as necessary. Most leaks are from the two halves of the seal being out of alignment with one another.
[Re: mopar dave]
#3095675
11/20/22 02:46 AM
11/20/22 02:46 AM
Posts: 43,284 Bend,OR USA
Cab_Burge
[Re: mopar dave]
#3095808
11/20/22 03:19 PM
11/20/22 03:19 PM
Posts: 19,589 north of coder
moparx
a gut reaction would be that if the engine wasn't occasionally turned over during the off season, maybe the seal slightly stuck to the crank, causing it to tear ever so slightly or deform a tiny bit, causing the leak ? as to using the right stuff, i wouldn't use that myself. as i think Cab [?] said, a clear silicone "adhesive" is the stuff to use. "adhesive" needs to be on the label. https://rainbowtech.net/wp-content/uploads/88000-Clear-RTV-Silicone.jpgi like this stuff, but i'm sure there are other products out there that are like this.
[Re: mopar dave]
#3095819
11/20/22 04:01 PM
11/20/22 04:01 PM
moparx
remember, i'm no engine builder. however with that said, i have seen countless recommendations to fill the side areas with silicone "adhesive". another tip to do with the rear seal retainer is drill out the bolt holes a size or two [depending on how the block threads are positioned and the seal retainer holes are drilled] to allow the retainer to center the seal on the crank, and thus the bolts can be tightened without moving the seal to one side or the other, causing the seal to be deformed.
[Re: mopar dave]
#3095834
11/20/22 05:01 PM
11/20/22 05:01 PM
Cab_Burge
OK, so use silicone adhesive and no side seals? No Use the side seals and silicone them full (both sides of the rear main seal holder, drivers and passenger sides :wrench) from the crankshaft flywheel flange side, I use a thin narrow putty knife to fill them from the sides of the crank shaft flange
[Re: mopar dave]
#3095888
11/20/22 09:57 PM
11/20/22 09:57 PM
Posts: 916 Arizona
Chucklehead
Arizona
I have used the one piece seal from Fast Fish Auto Parts. No leaks or sealing issues on a 470 stroker.
Still Broke
[Re: Chucklehead]
#3095954
11/21/22 10:33 AM
11/21/22 10:33 AM
Posts: 2,007 Apollo, PA.
B1MAXX
Apollo, PA.
I fill the sides with rtv, then I shove a piece of precut 3/32 or 1/8 welding rod in there and it forces the rtv out slightly. I like seeing the expanded bead on retainer from top to bottom of the edge gap. Just my twist on this personal subject. I also put the seal in 12/6. And I wouldn't drill the holes seems that could add to the alignment issue. I have reduced the height slightly by flat sanding/milling approximately .010 off for a little extra crush. Most of the time its just the black rubber seal.
[Re: B1MAXX]
#3096031
11/21/22 01:39 PM
11/21/22 01:39 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I fill the sides with rtv, then I shove a piece of precut 3/32 or 1/8 welding rod in there and it forces the rtv out slightly. A piece of pipe cleaner moistened with water works better, RTV cures by exposure to moisture.
[Re: John_Kunkel]
#3096076
11/21/22 03:40 PM
11/21/22 03:40 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
A piece of pipe cleaner moistened with water works better, RTV cures by exposure to moisture.....
As Joe K indicates above... this is very critical... In fact, if you read the installation instructions from Fel-Pro sets, its exactly what they say... I wrote those instructions when I worked for Fel-Pro.[i][/i]
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: mopar dave]
#3096352
11/22/22 04:04 PM
11/22/22 04:04 PM
feets
Senior Management
Senior Management
Irving, TX
I used the blue silicone side seals that came with the Viton main seal. The ends of the seals got a little red Permatex adhesive. It looks like Loctite not RTV.
If you drop the seal in the block then slide the retainer with seal in place you can look through the crank hole and see how the seals line up fore/aft. That will give you a good idea of what to do.
Other than that, you need to put a little oil/grease/assy lube on the crank and test fit the rear main. Give the crank a quarter turn or less and check the witness marks in the lube. You can see if the ends of the seal are lining up properly.
If they're not lined up perfectly then none of the above tricks will work. It will leak.
