Concreted in Aluminum Indy blocks. #3094760
11/16/22 05:37 PM
11/16/22 05:37 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
By chance anyone ever weigh one? (9.98 deck) ...Thanks.
Re: Concreted in Aluminum Indy blocks. [Re: racerx] #3094834
11/16/22 11:29 PM
11/16/22 11:29 PM
I wouldn't waste my time or money filling any water block for drag racing or any other use down tsk
One of the main reasons I'm against using concrete based fillers is all concrete shrinks while curing, pulling away from the block in all ways, cylinders and all other surfaces.
Another thing about partial fills is the block heat being differently above the fill than below it., I dyno a 1971 340 NHRA stocker motor that Greg Luneack (SP?) built for the customer, that block was about a 3/4 fill. it was slightly below the water inlet holes on the front of the block from the water pump. They like to race it with 130 F water temps so we were doing that on the engine dyno, we used a laser heat gun to measure the tempts of the block and heads, the heads read 130 F after several pulls and the block read 180F below the water in the block down in were the fill was shock puke Not good on the ring seal, HUH work
There are some composite fillers that may not shrink when curing, but which type and brand I have no idea of and I have never heard much about them either shruggy work
How much power are you wanting to make?
Re: Concreted in Aluminum Indy blocks. [Re: Cab_Burge] #3094864
11/17/22 05:30 AM
11/17/22 05:30 AM
birdtracker Offline
birdtracker  Offline
https://www.competitionproducts.com...ler-25-lbs/productinfo/ROK/#.Y3X-zX3MLIU
I filled mine. So far so good. Currently not running coolant and not as heavy as old school stuff. Birdtracker
Re: Concreted in Aluminum Indy blocks. [Re: birdtracker] #3094896
11/17/22 10:02 AM
11/17/22 10:02 AM
PA
moparacer Offline
moparacer  Offline
PA
Pretty sure we used that Rockblock in one of mine once because of the quick cure time. Pulled it down a year or so later and it had shrank.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Concreted in Aluminum Indy blocks. [Re: racerx] #3094900
11/17/22 10:24 AM
11/17/22 10:24 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Why would anybody fill an aluminum block - seems counter productive and a waste of time - I see no gain to be had. If you want a solid block (no water jacket) order one
Re: Concreted in Aluminum Indy blocks. [Re: DoubleD] #3094905
11/17/22 10:53 AM
11/17/22 10:53 AM
an8sec70cuda Offline
iagree If you need to concrete an aftermarket aluminum block...then you are starting w/ the wrong block. As much as aluminum blocks move around, filling one w/ concrete is not something I'd be doing.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Concreted in Aluminum Indy blocks. [Re: an8sec70cuda] #3094906
11/17/22 10:56 AM
11/17/22 10:56 AM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
Agreed
Re: Concreted in Aluminum Indy blocks. [Re: DoubleD] #3094907
11/17/22 11:01 AM
11/17/22 11:01 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Because an aluminum block will move around some. My INDY block is now half filled with Rock Block. It was mainly done to help stiffen the block up, as it was previously damaged. I was told an aluminum block will not pull vacuum like a iron block, but I was able to pull a steady 10lbs, at idle, and went over 20 before adjusting the relief valve.
69 GTX 68 Road Runner
Re: Concreted in Aluminum Indy blocks. [Re: birdtracker] #3094917
11/17/22 11:31 AM
11/17/22 11:31 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
133+25=158 does sound better that a stock block weight wise............Thank you thumbs
Re: Concreted in Aluminum Indy blocks. [Re: moparacer] #3094918
11/17/22 11:35 AM
11/17/22 11:35 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
frowwn.... That's not good is this N/A or boosted?
Re: Concreted in Aluminum Indy blocks. [Re: an8sec70cuda] #3094925
11/17/22 11:47 AM
11/17/22 11:47 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
I'm trying to determine if i going to pull the trigger on an Indy Maxx block on a boosted setup work (short deck) Indy rated there blocks to 1500 HP i'm not a big fan of aluminum moving around, but i still will like to keep it streetable I'm in the research stages now reason for this post,......Thanks .... lots of interesting opinion here thumbs
Re: Concreted in Aluminum Indy blocks. [Re: Cab_Burge] #3094927
11/17/22 11:52 AM
11/17/22 11:52 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Cab....i sent you a pm.
Re: Concreted in Aluminum Indy blocks. [Re: JERICOGTX] #3094928
11/17/22 11:52 AM
11/17/22 11:52 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Rock Block is nothing more than a hydraulic grout (i.e. Rock-Ite) with powdered iron added - hence its expansion ratio is advertised as somewhat closer to iron - Its not really designed for aluminum blocks. There are grouts available for working around aluminum and concrete but I don't know anybody that has ever used them. Indy blocks move even new - the cylinder liners move up and down after time - and the block moves around from expansion. I would guess if you looked at the grout added after awhile I will bet its moved around also.
I have grouted factory blocks in the past and even experimented with Epoxy Grout (Devcon) put in under heat & pressure - that seemed to work the best but was a huge pain to do it and the cylinder walls definitely moved out of round more than rock-block - in the end you still have a stock block with stock main web design
Re: Concreted in Aluminum Indy blocks. [Re: JERICOGTX] #3094932
11/17/22 11:55 AM
11/17/22 11:55 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
up....How is that block holding up for you? And at what power level?
Re: Concreted in Aluminum Indy blocks. [Re: racerx] #3094948
11/17/22 12:35 PM
11/17/22 12:35 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If you want a filler why not pour molten aluminum in the block. Get the block around 6-7 hundred degrees then pour
Re: Concreted in Aluminum Indy blocks. [Re: racerx] #3094992
11/17/22 02:41 PM
11/17/22 02:41 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Well it only has dyno time, and it made 870hp.
Re: Concreted in Aluminum Indy blocks. [Re: racerx] #3095039
11/17/22 05:05 PM
11/17/22 05:05 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Is that desire actually compatible with a filled block?
Re: Concreted in Aluminum Indy blocks. [Re: JERICOGTX] #3095067
11/17/22 07:17 PM
11/17/22 07:17 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
thumbs
Re: Concreted in Aluminum Indy blocks. [Re: GomangoCuda] #3095069
11/17/22 07:20 PM
11/17/22 07:20 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
shruggy
Re: Concreted in Aluminum Indy blocks. [Re: racerx] #3095184
11/18/22 11:33 AM
11/18/22 11:33 AM
birdtracker Offline
birdtracker  Offline
for my use I wish I could of got a filled block. I found this water block and after 3 different pressure tests and having the sleeves installed, cam bearings, line bored, finished honed and then assembled found out it leaked coolant into the oil. So then after another 6 month go around of trying sealers and changing the oil and cleaning out valve covers, oil, pan and filter, I decided to fill it to the bottom of the water pump opening. No coolant, just a oil heater in the oil pan to warm it up before running. I made 3 back to back to back 1/4 mile passes and oil temps never got over 190 degrees. So the answer to why fill an aluminum block is how deep are you into it. Some day if I have to take a cylinder head off I will look and see how it lasted.Birdtracker
