torque specs for BMP aluminum block #3094626
11/16/22 12:17 PM
11/16/22 12:17 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Anyone have the torque specs for the mains on the Bill Mitchell Hemi block? Also, when checking bearing clearance on mains, do i need the torque the lateral bolts?
Re: torque specs for BMP aluminum block [Re: mopar dave] #3094639
11/16/22 12:56 PM
11/16/22 12:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Block torque specs are here. You should have gotten an instruction sheet with it as well. And yes you should torque ALL the fasteners when checking clearance, runout etc.
https://billmitchellproducts.com/tech/
Re: torque specs for BMP aluminum block [Re: Al_Alguire] #3094644
11/16/22 01:06 PM
11/16/22 01:06 PM
Mt Morris Michigan
Mt Morris Michigan
I did not receive that. the block was shipped direct to machine shop. Thanks Al.
Re: torque specs for BMP aluminum block [Re: Al_Alguire] #3094868
11/17/22 07:21 AM
11/17/22 07:21 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I read the torque spec's in the PDF and has the mains being torqued to 100 FT Lbs. & the side bolts torqued to 45 FT Lbs. My KB blocked is stamped to torque the mains to 120 FT Lbs. & 80 FT Lbs. on the side bolts shruggy
Re: torque specs for BMP aluminum block [Re: RATTRAP] #3094874
11/17/22 08:18 AM
11/17/22 08:18 AM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
And ARP calls for 110 ft/lbs when using their main studs... shruggy
Re: torque specs for BMP aluminum block [Re: powertrip] #3094877
11/17/22 08:22 AM
11/17/22 08:22 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Follow the directions for the block you have...
Re: torque specs for BMP aluminum block [Re: RATTRAP] #3094915
11/17/22 11:21 AM
11/17/22 11:21 AM
NC
440Jim Offline
440Jim  Offline
NC
Different block, different fasteners, etc. For example, the side bolts on the BMP block are 3/8" dia.
And the block should be machined at the same specs it is assembled at.
Re: torque specs for BMP aluminum block [Re: Dragula] #3094971
11/17/22 01:30 PM
11/17/22 01:30 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
