Park brake pedal release bushing #3093807
11/12/22 08:48 PM
11/12/22 08:48 PM
New England
Tech Instructor Offline OP
New England
Where can I purchase the guide bushing for the brake release rod.
Re: Park brake pedal release bushing [Re: Tech Instructor] #3093884
11/13/22 10:14 AM
11/13/22 10:14 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Here’s an old thread on the item I believe you’re looking for. I made my own using material from the hardware store and the original I removed (images within the thread). It was very easy to make if you have access to a small lathe.
The short story is that unless something has changed the detail wasn’t being offered by any of the usual parts suppliers.
https://board.moparts.org/ubbthread...ng-brake-handle-grommet.html#Post1752240
Good luck, you can do it !!!
Re: Park brake pedal release bushing [Re: AAR#2] #3094194
11/14/22 06:07 PM
11/14/22 06:07 PM
MoreParts Offline
MoreParts  Offline
I am pretty sure someone found a pretty close to exact replacement for these as a general part from a hardware store sold in packs of 20. I think it was posted at https://www.e-bodies.org/ around 6 or so months ago.
Re: Park brake pedal release bushing [Re: MoreParts] #3094374
11/15/22 01:53 PM
11/15/22 01:53 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
PM sent...i have some leftovers
Re: Park brake pedal release bushing [Re: RP's R/T's] #3094417
11/15/22 04:13 PM
11/15/22 04:13 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
RP'S check your PM
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Park brake pedal release bushing [Re: Tech Instructor] #3094542
11/16/22 12:18 AM
11/16/22 12:18 AM
P
PasiR Offline
PasiR  Offline
P
Mega Parts.
Re: Park brake pedal release bushing [Re: PasiR] #3094973
11/17/22 01:37 PM
11/17/22 01:37 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
the Mega Parts kit is a rubber grommet.
I have tried to use that but don't like it as much as a white nylon bushing.
Re: Park brake pedal release bushing [Re: RP's R/T's] #3095154
11/18/22 07:41 AM
11/18/22 07:41 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
It doesn’t appear a rubber grommet is correct for any year/model, and suspect it’s just a functional replacement
Re: Park brake pedal release bushing [Re: AAR#2] #3130115
03/17/23 12:13 PM
03/17/23 12:13 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Someone recently posted an after market part number for the nylon bushing any body know what it is
NS1AAR
Re: Park brake pedal release bushing [Re: ns1aar] #3130197
03/17/23 05:58 PM
03/17/23 05:58 PM
MoreParts Offline
MoreParts  Offline
I remember this too. The part looked like the original. I think it was a part that Granger or Fastenal sold, but you had to buy them in bulk. It may have been mentioned at e-bodies.org.
BTW, nice seeing another IE ebody guy!
Re: Park brake pedal release bushing [Re: MoreParts] #3130281
03/18/23 09:35 AM
03/18/23 09:35 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Re: Park brake pedal release bushing [Re: EW1BH27] #3130291
03/18/23 10:28 AM
03/18/23 10:28 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Interesting and shows promise, but we are on the “Restoration and A12” forum.
I’ll be curious what each feature measures relative to original.
That said, for many it may be close enough and functional.
Hopefully the fellow that bought a box will update once he has them.
These are very easy to make (with one caveat - you need to have or know a friend with a lathe)
Re: Park brake pedal release bushing [Re: AAR#2] #3130410
03/18/23 06:59 PM
03/18/23 06:59 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
So I decided to dig for my original and take caliper dimensions, the image attached shows what I got from my bushing, and short of the overall length I would have to say that it matches dimensionally. Of course overall length can be easily overcome since the shoulder height appears good, from memory I don’t recall if the added length would make a difference but suspect not. Mine appears deformed or a poor cut on the length opposite the shoulder, and why the large tolerance of .020” is shown
The outside dia of the shoulder is close enough that no one would be able to tell less calipers
The only other item that may be out would be the color, listed as white, where the original is more translucent/yellow, and may be a result of time.
I’d like to see one now, but suspect it’s good.
Wanted to post up after questioning the dimensions.
Re: Park brake pedal release bushing [Re: AAR#2] #3130543
03/19/23 01:20 PM
03/19/23 01:20 PM
moparx Offline
moparx  Offline
would the year, or parts supplier, dictate the color of that bushing ?
being curious, i looked at the one on my charger which i have owned since 1970, and it's color is black.
i'm positive it's original, as that assembly has never been removed from the car since i have owned it.
beer
Re: Park brake pedal release bushing [Re: moparx] #3130577
03/19/23 03:04 PM
03/19/23 03:04 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
beer
Appears black is very common
https://board.moparts.org/ubbthread...rake-release-handle-spring-retainer.html
Re: Park brake pedal release bushing [Re: AAR#2] #3130619
03/19/23 05:28 PM
03/19/23 05:28 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Park brake pedal release bushing [Re: mopars4ever] #3130650
03/19/23 07:50 PM
03/19/23 07:50 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
good price.... but 40..... dang
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Park brake pedal release bushing [Re: AAR#2] #3130888
03/20/23 03:30 PM
03/20/23 03:30 PM
moparx Offline
moparx  Offline
beer
after [re]reading your link, my noggin remembered a few things from "yesteryear". thanks for jogging/shaking up the old snow globe. up
beer
