434 big block torque converter questions
#3092243
11/07/22 10:39 AM
11/07/22 10:39 AM
Posts: 12,008 Finally a HUSKER again
Moparnut426
Not quite ready to bolt it in the Bee yet, still doing body and paint, but I should have the majority don't this winter. so the 434 is on my run stand, and I am getting ready to order up a converter. The 434 is a pretty basic combo, 440 source heads completely re worked cause they came in the box pretty junky spring, and retainer wise. The short block has diamond flat tops and compression is pretty dead nuts at 10:1. using a old eddy DP dual plane intake, and a Hughes cam, if I remember correctly its in the 230@.050 range, and 530 ish lift.
Car has a 3.54 geared dana in it, and i'm curious whos converter you guys run with the beat luck. NOT A RACE/DRAG CAR!!! This is a daily car I'm building so I don't want a stupid high stall, but I want it to be fun! every other car I have is a stick, so I'm at a loss for ordering a converter. Do I order the converter off of the cam card? Curious on what you guys do in this department.
Re: 434 big block torque converter questions
[Re: A727Tflite]
#3092352
11/07/22 04:14 PM
11/07/22 04:14 PM
Moparnut426
A stock 383 roadrunner converter.
Any idea what kind of torque it will make ? Boy I honestly don't know, Id hope for 450? I wouldn't think that number is out of line... This is the camshaft from my memory. The card is in my tool box at my home shop.
[Re: dvw]
#3092454
11/07/22 11:05 PM
11/07/22 11:05 PM
Posts: 3,916 usa
lewtot184
usa
factory 10 3/4" converter should easily handle that cam.
it would be interesting to know the actual seat timing for that cam.
another thought; what exhaust?
[Re: lewtot184]
#3092608
11/08/22 04:19 PM
11/08/22 04:19 PM
Moparnut426
another thought; what exhaust? Iron Manifolds, and a OE exhaust from Gardner exhaust..... I might use another company depending on time lines...
