Page 2 of 3 1 2 3
Re: Rumors re MoPig progress may be true [Re: moparx] #3092111
11/06/22 07:32 PM
11/06/22 07:32 PM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
wrench
hammer
sawzall
bondo
primer
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Rumors re MoPig progress may be true [Re: Brad_Haak] #3092158
11/06/22 10:17 PM
11/06/22 10:17 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Brad... were you planning to run an air pan with that hood?
Re: Rumors re MoPig progress may be true [Re: racerx] #3092199
11/07/22 12:50 AM
11/07/22 12:50 AM
Loudoun County, VA
Loudoun County, VA
Yep
Re: Rumors re MoPig progress may be true [Re: Brad_Haak] #3092218
11/07/22 07:25 AM
11/07/22 07:25 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Yep
Keep this updated if possible been trying to figure out a design for mine, but my intake sits to high work
Re: Rumors re MoPig progress may be true [Re: racerx] #3092227
11/07/22 09:11 AM
11/07/22 09:11 AM
Loudoun County, VA
Loudoun County, VA
Gonna make a new one the same way I did one before:
- find a drop-style air cleaner base that lowers the filter surface below the surface of the hood
- cut out a cardboard template that matches the underside of the hood that you want to seal off
- cut out an opening in the template where the air cleaner base will mount
- get a sheet of thin luan (?) wood and cut to match cardboard template
- pop-rivet or screw air cleaner base to wood sealing plate
- get some fire-resistant foam (I use what Moroso sells)
- it requires trial & error test fittings to determine how much foam to glue on perimeter of sealing plate
If you have room for an air filter, installing the complete filter housing holds the sealing plate in place
Otherwise, the hood itself when closed may hold it in position; that's how my last one worked
Re: Rumors re MoPig progress may be true [Re: Brad_Haak] #3092233
11/07/22 09:55 AM
11/07/22 09:55 AM
Loudoun County, VA
Loudoun County, VA
Here's the one for this hood...
Re: Rumors re MoPig progress may be true [Re: Brad_Haak] #3092239
11/07/22 10:11 AM
11/07/22 10:11 AM
Loudoun County, VA
Loudoun County, VA
I'm expecting the Braswell base on the right will lower the plate enough to use w/ this head & intake combo that pushes the carb mounting surface up even more than before. Since I have only 4150 carbs, I've probably got more options for air cleaner configurations.
Re: Rumors re MoPig progress may be true [Re: Brad_Haak] #3092293
11/07/22 01:42 PM
11/07/22 01:42 PM
Mo.
racerx Offline
racerx  Offline
Mo.
What intake you use? That wood looks kind of thick.
Re: Rumors re MoPig progress may be true [Re: racerx] #3092309
11/07/22 02:06 PM
11/07/22 02:06 PM
Loudoun County, VA
Loudoun County, VA
The wood is only ~ .200" thick, yet still does a good job of isolating heat from the carb. You can put your hand on the hood when the engine's been running and feel a noticeable temp diff between the hood exposed to under-hood heat and the hood isolated by the sealing pan.
I have a Trick Flow intake on top of Victor heads, so a tall intake w/ raised intake ports shifts the carb up quite a bit.
Re: Rumors re MoPig progress may be true [Re: Brad_Haak] #3092312
11/07/22 02:09 PM
11/07/22 02:09 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Roger that up....Thx you up
Re: Rumors re MoPig progress may be true [Re: racerx] #3093025
11/10/22 01:58 AM
11/10/22 01:58 AM
Loudoun County, VA
Loudoun County, VA
Anyone have any thoughts or experience with knowing what happens when your hood scoop is too big? Does it jack with your tune, or...? Thx
Re: Rumors re MoPig progress may be true [Re: Brad_Haak] #3093065
11/10/22 09:23 AM
11/10/22 09:23 AM
Loudoun County, VA
Loudoun County, VA
After further digging into the subject... I guess this will be "interesting" to figure out on my own
Long story short is that scoop opening is waaaaaayyyyy too freakin' big IMO, but it is what it is
Re: Rumors re MoPig progress may be true [Re: Brad_Haak] #3093069
11/10/22 09:29 AM
11/10/22 09:29 AM
an8sec70cuda Offline
It is big, but it isn't THAT tall. Not way up in the "good" air so to speak. Although the 6 pack hood I used to have on my car was worth a tenth to a tenth and a half when it was sealed to the carb. So they do work even when they're kinda short.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Rumors re MoPig progress may be true [Re: an8sec70cuda] #3093080
11/10/22 10:07 AM
11/10/22 10:07 AM
Loudoun County, VA
Loudoun County, VA
I saw the same amount of improvement from sealing the stock T/A scoop setup vs running the scoop w/o a fresh-air plate
As far as the scoop being "too big", I'm not the first -- or only -- person to run a Big-N-Ugly one. VFN doesn't offer this style any longer (not on their web site now), but "340Rick" had theirs on his Chally. Not identical, but still pretty close.
Re: Rumors re MoPig progress may be true [Re: Brad_Haak] #3093218
11/10/22 06:59 PM
11/10/22 06:59 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
While you are fabbing up your air pan. Is it possible to maybe leave enough area to build some sort of dam to slow the air down
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Rumors re MoPig progress may be true [Re: 67mprfan] #3093341
11/11/22 09:17 AM
11/11/22 09:17 AM
Loudoun County, VA
Loudoun County, VA
I have a couple of ideas on things I may need to try out, including plugging off one half of the scoop, air "baffles" (like you mentioned), spring-loaded trap doors to allow some amount of excess airflow to vent... work
Re: Rumors re MoPig progress may be true [Re: Brad_Haak] #3093357
11/11/22 09:58 AM
11/11/22 09:58 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If the scoop is sealed to the hood then I would imagine it would build pressure and maybe not be as turbulent as it would be if there was no pan or sealing to the hood. I know some EFI guys I follow have noted positive manifold pressure with those lexan scoops.
68 Barracuda Formula S 340
Re: Rumors re MoPig progress may be true [Re: Brad_Haak] #3093369
11/11/22 10:17 AM
11/11/22 10:17 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I remember years ago Thumper had mention something about adding release holes in the back of his hood scoop to release turbulence to his carbs. It made sense. I put hole in the rear of my hood to release under hood pressure because I had pressure building on the top end where the hood would stress crack.
Re: Rumors re MoPig progress may be true [Re: racerx] #3093400
11/11/22 11:48 AM
11/11/22 11:48 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
That’s what I did. up
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Rumors re MoPig progress may be true [Re: BloFish] #3093445
11/11/22 01:32 PM
11/11/22 01:32 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Lexan scoops are an issue, they simply don't have enough volume in that small space, so yes they need to be vented. A properly sized scoop for the engines needs does NOT need to be vented in any way. There are anumber of sources out there to help determine what sixe your engine actually NEEDS.
Here is just one article on the subject but its not difficult to calculate the volume needed
https://www.enginelabs.com/engine-t...p-speed-with-a-forward-facing-air-inlet/
Page 2 of 3 1 2 3
