Need advice 360 timing chain cam/crank slightly off
#3090955
11/01/22 02:48 PM
11/01/22 02:48 PM
Posts: 133 Parsippany, New Jersey
340challconvert
Purchased a 360 from Mabco to put into my A66 340 Challenger short term while I pull the 340 for a rebuild. I bought a hp version with flat top pistons and installed hp cam sited as a 272 cam Cam specs; 272-272 duration 454 lift 110 lobe separation 52 degrees overlap, 216 216 duration @ .50 Power range 1500-5200 Considered the largest "stock" cam for this engine
In going over the engine for parts install; the timing marks are slightly off. I call the manufacturer and he stated to leave the chain as is.
Pistons are flat top 30 over, no valve notches, piston to deck measurement is not a stock (deep in the hole) 360 with the higher compression pistons it measures out at about .087 below deck with number 1 piston at TDC.
I am no expert, and I have installed cams years back always aligning timing marks; is there a reason for the manufacturer to alter the timing in this manner with this hp cam and flat top piston? Pic of timing chain sprockets and Number 1 piston at TDC Any thoughts appreciated.
1970 A-66 340 Challenger convertible
Re: Need advice 360 timing chain cam/crank slightly off
[Re: 340challconvert]
#3090956
11/01/22 02:49 PM
11/01/22 02:49 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
You need to degree the cam with a degree wheel
[Re: CSK]
#3090988
11/01/22 05:18 PM
11/01/22 05:18 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
You need to degree the cam with a degree wheel The first solid roller cam I bought and installed for a customer was ground 10 degrees retarded I've also had 10 sets of Cloyes BB Mopar timing sets that came with the wrong cam gear My message is never trust any part to be correct, especially with any Hi Po parts in your motors You'll need a solid lifter, a degree wheel and a dial indicator with 1.0 inch reading with an extension long enough to reach the lifter cup The quickest way to check the cam for proper lobe timing is to check the lobe separation angles at .050 before and after max lift on the lobes with the solid lifter, check the intake lobe first and then check the exhaust lobe second, if the intake lobe is correct (installed straight up) at max lift at 110 ATDC the exhaust lobe should be 110 BTDC at max lift, if the cam is installed 4 degrees advance the intake lobe center should be at 106 ATDC and the exhaust lobe should be at 114 BTDC I always check the lobe lift also before checking the LSA on the cams Cloyes made a batch of BB upper cam gears that would not align dead nuts straight up and down with the crank gear, if the cam dot was to the drivers side of the motor the cam was retarded around 12 degrees and the motors would run like crap If you moved the cam gear so the crank gear dot was to the passenger side of the motor it is was closer to being install correctly Take your time to make sure the cam is installed correctly on the lobe separation angles, you don't want it to hurt parts or have it run like Doo Doo Let us know what ends up with this problem please
#3090992
11/01/22 05:52 PM
11/01/22 05:52 PM
Guitar Jones
Looks like you have the cam at least one tooth off. And BTW that is #6 firing, not #1.
[Re: Guitar Jones]
#3091005
11/01/22 07:37 PM
11/01/22 07:37 PM
Posts: 4,954 WI
Dcuda69
WI
Looks like you have the cam at least one tooth off. And BTW that is #6 firing, not #1. Agree on both points. Line those dots up, then get the degree wheel out to find out where the cam actually is. Good luck!
[Re: Dcuda69]
#3091267
11/02/22 09:08 PM
11/02/22 09:08 PM
Posts: 2,523 God's Country Maryland
GODSCOUNTRY340
I just lined up a straight edge on his pic from center of crank bolt to center of cam bolt and both dots are off. Looks like you have the crank spun too far past TDC. Back it up and both will most likely line up.
[Re: AARCONV]
#3091288
11/02/22 10:34 PM
11/02/22 10:34 PM
Guitar Jones
They make an offset keyway They make them in 2°-4°-6° & 8° off sets.
[Re: GODSCOUNTRY340]
#3091290
11/02/22 10:36 PM
11/02/22 10:36 PM
Guitar Jones
I just lined up a straight edge on his pic from center of crank bolt to center of cam bolt and both dots are off. Looks like you have the crank spun too far past TDC. Back it up and both will most likely line up. Cam turns at half speed, that is still a tooth off.
#3091388
11/03/22 12:46 PM
11/03/22 12:46 PM
Posts: 15,429 Omaha Ne
TJP
Omaha Ne
