Which recommended 727 rebuild kit? #308946
05/05/09 07:06 PM
05/05/09 07:06 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Wanting to rebuild a 69-727 and need to know what best complete rebuild kit to use on my 727. Best kit that has the best bands, etc., in it.
Also, what are the easiest and cheapest performance upgrades?
This is for an 440-6 pack A12 that is an all stock motor.
Re: Which recommended 727 rebuild kit? [Re: cdp] #308947
05/05/09 08:43 PM
05/05/09 08:43 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
www.transtar1.com
I just used them for a 727 I just built , even got the TF2 kit there as well, although they were a bit pricier on the TF2 kit versus summit or mancinis,jegs etc , but I saved on shipping
Re: Which recommended 727 rebuild kit? [Re: cdp] #308948
05/05/09 09:12 PM
05/05/09 09:12 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I've always used the Turbo Action "Tranz Box" kit.
www.turboaction.com
Nautilus Racing-
Re: Which recommended 727 rebuild kit? [Re: Chris2581] #308949
05/05/09 10:25 PM
05/05/09 10:25 PM
Thunder Bay,ON
LilRedDave Offline
LilRedDave  Offline
Thunder Bay,ON
I bought the Mancini kit (which was just the Mopar kit with the Mancini sticker right over the Mopar sticker) and it works great so far behind a hot small block. Had Raybestos plates inside (not blue)Do yourself a favor and replace all (especially the reverse one)the servo's with billet ones. I bought them direct from Sonnax Best price and a really quality product
Re: Which recommended 727 rebuild kit? [Re: LilRedDave] #308950
05/06/09 01:22 AM
05/06/09 01:22 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i have used several transtar kits from northern autoparts...727...42rh, 46rh and 46re and 904.
it seems to be the most completed kit with front band...bushing..washers that others charge extra for...
http://northernautoparts.com/ProductDetail.cfm?ProductId=1943
Tony
70 AARCuda Vitamin C
Re: Which recommended 727 rebuild kit? [Re: 70AARcuda] #308951
05/06/09 09:36 PM
05/06/09 09:36 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
Im gonna bump this thread cause I wanna get some more imput on a good HD transmission rebuild kit. Im not interested in over the top race application, but I do want a good sturdy rebuild kit.
Re: Which recommended 727 rebuild kit? [Re: gomangoRTSE] #308952
05/06/09 10:30 PM
05/06/09 10:30 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Since I have a 69 trans, should I upgrade to the later part throttle kick down valve body?
Re: Which recommended 727 rebuild kit? [Re: cdp] #308953
05/06/09 11:46 PM
05/06/09 11:46 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I've read the part throttle kickdown is 69 and up. you should be good
Re: Which recommended 727 rebuild kit? [Re: bboogieart] #308954
05/07/09 07:55 AM
05/07/09 07:55 AM
MO
cdp Offline OP
cdp  Offline OP
MO
I thought it was 71 up.
Re: Which recommended 727 rebuild kit? [Re: cdp] #308955
05/07/09 10:24 AM
05/07/09 10:24 AM
NE Ohio
71 FJ6 Charger Offline
NE Ohio
Contact John I believe his name is at CRT,advertised on here. I think he has a stock build kit for $75 and HP for around twice that.
If not him,I would suggest the T2 kit.But from what I hear,the T2 kit has questionable parts from 70 and earlier I think and 71 and up. Sealing rings are one thing I remember. I would check into CRT,maybe he'll do something for Moparts members,dont know. WILDBILL should be chiming in anytime to comment. He runs a 10-11 sec. 71 Charger and swears by him and his parts.Talked to him a few times,seems like a straight up dude!Offered to help me build mine one of these weekends using a CRT kit.
'71 383HP FJ6 Charger SE
Re: Which recommended 727 rebuild kit? [Re: 71 FJ6 Charger] #308956
05/07/09 01:34 PM
05/07/09 01:34 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
http://www.coperacingtrans.com/
or PM CRT here on the site -
John tells you like it is, and he wont sell you more then you need - just to make a buck!
He's as good as they come!
Re: Which recommended 727 rebuild kit? [Re: bboogieart] #308957
05/07/09 05:04 PM
05/07/09 05:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
PTK for V8's started in '71, for the /6 it was '67.
