Page 2 of 3 1 2 3
Re: impressive run F.A.S.T. Duster [Re: burdar] #3088076
10/21/22 02:02 PM
10/21/22 02:02 PM
moparx Offline
moparx  Offline
i will have to look at my buddy's duster.
i thought his had that rib, but i could be mistaken. [sure wouldn't be the first time i don't know what i'm remembering. laugh2]
beer
Re: impressive run F.A.S.T. Duster [Re: topside] #3088077
10/21/22 02:04 PM
10/21/22 02:04 PM
moparx Offline
moparx  Offline
Originally Posted by topside
Yes, ridge from '72 up, IIRC, which would include the Feather Duster aluminum lid.
I would think that given all the limitations those guys have, they'd sure be looking at weight anywhere they can pare it.
ahhh........you treed me !
my buddy's duster is a 72, so it must have the rib.
it's not a feather duster however.
beer
Re: impressive run F.A.S.T. Duster [Re: dvw] #3088083
10/21/22 02:25 PM
10/21/22 02:25 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
That car is a good example of what can be achieved when you refine a combo over a long period of time.
They just keep pecking away at it.
Re: impressive run F.A.S.T. Duster [Re: fast68plymouth] #3088104
10/21/22 03:27 PM
10/21/22 03:27 PM
AndyF Offline
AndyF  Offline
Absolutely correct. I've run engines on the dyno and then the car doesn't run the "number" right off the trailer and people start yapping about dyno numbers. Then a year later the car is running 0.50 or even a full second quicker without any changes to the engine. It just takes a lot of work to get the right converter in the car hooked up to the correct gear ratio and tire size and shift speeds and suspension settings, etc. The really skilled guys can sort a car out in a few outings but other guys have to peck away at if for a full season or maybe even a couple of seasons. Especially if they are budget limited.
Re: impressive run F.A.S.T. Duster [Re: GY3] #3088147
10/21/22 07:17 PM
10/21/22 07:17 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Originally Posted by GY3
Horspower Depot has a Youtube channel that is really interesting.
Granted, they're racing BBC in Corvettes and a '69 Camaro in F.A.S.T. but it's super interesting to see them test and find out what works and what doesn't. Apparently sidepipes on 'Vette kill about 40 hp over rear exit exhaust! Crazy!
They've been 9.31's at 147mph in a factory appearing Corvette and 9.50's in the Camaro.
I witnessed the 9.31 pass at Indy. Unbelievable.
Doug
Re: impressive run F.A.S.T. Duster [Re: GY3] #3088158
10/21/22 08:30 PM
10/21/22 08:30 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Here's a video about the Camaro where he "reveals his secrets". Have to wonder what was left out.
They are running hidden Holley EFi stuff to control timing and data log. Don't know if that alone makes them faster per-se but it does give them a better handle on their data with all the sensors. You can run whatever sensors you want with the Dominator modules - wheel sensors, driveshaft speed, etc. It all helps.
Over the summer I spoke directly with one of the more competitive F.A.S.T. racers about this idea and he basically admitted he was behind the curve without it.
'71 Duster
'17 Ram 1500
Re: impressive run F.A.S.T. Duster [Re: RMCHRGR] #3088164
10/21/22 08:45 PM
10/21/22 08:45 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I thought the electric vacuum pump he showed recently was pretty cool. You can see it in the passenger floor if you look carefully and he turns it on with the cigarette lighter knob.
'63 Dodge 330
11.19 @ 121 mph
Re: impressive run F.A.S.T. Duster [Re: GY3] #3088174
10/21/22 09:29 PM
10/21/22 09:29 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
[quote=RMCHRGR]I thought the electric vacuum pump he showed recently was pretty cool. You can see it in the passenger floor if you look carefully and he turns it on with the cigarette lighter knob.
It's one of the coolest forms of racing but it may be at the point where it can't go much farther because of the safety requirements. Might be tough to call them "Factory Appearing" anymore when they start needing 8.50 cages.
'71 Duster
'17 Ram 1500
Re: impressive run F.A.S.T. Duster [Re: RMCHRGR] #3088190
10/21/22 10:35 PM
10/21/22 10:35 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
[quote=GY3]
I didn't watch the video so forgive me if it's been stated but if they have the above equipment they have everything they need for traction control.
Re: impressive run F.A.S.T. Duster [Re: INTMD8] #3088192
10/21/22 10:47 PM
10/21/22 10:47 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Is it true they shave their tires.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: impressive run F.A.S.T. Duster [Re: INTMD8] #3088195
10/21/22 10:57 PM
10/21/22 10:57 PM
IL
8
83hurstguy Offline
83hurstguy  Offline
IL
Traction control is technically illegal per the rules, but the advantage of using an ECU to pre-program a timing curve is a huge advantage to getting the cars to leave on these tires.
You pretty much have to shave bias plies to true them up at a minimum. The repro tires do hook a lot better as they get down to the tread bars or less... you can run them bald.
The Duster hauls... impressive car.
Re: impressive run F.A.S.T. Duster [Re: 83hurstguy] #3088205
10/21/22 11:37 PM
10/21/22 11:37 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
The 32 pound tire pressure does not work. More like 45 PSI or more. Back seats are just a frame with no springs is one of the tricks. Definitely a thinking mans game. ETC
Re: impressive run F.A.S.T. Duster [Re: pittsburghracer] #3088211
10/22/22 01:11 AM
10/22/22 01:11 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Shaved down till there is only about 1/8 of an inch of tread left. In one video they have close-up pictures and also give break in procedures. They used to have a local circle car racer shave the tires, but they finally bought the machine and just do it themselves.
Re: impressive run F.A.S.T. Duster [Re: John Brown] #3088228
10/22/22 01:49 AM
10/22/22 01:49 AM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Officially set the record with a 10.52. Might be a touch more in it tomorrow, but we will see.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: impressive run F.A.S.T. Duster [Re: F1Scamp] #3088229
10/22/22 01:54 AM
10/22/22 01:54 AM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Normal 10 second small block.
Re: impressive run F.A.S.T. Duster [Re: pittsburghracer] #3088241
10/22/22 07:50 AM
10/22/22 07:50 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Think i remember someone said that in one of their videos work
Re: impressive run F.A.S.T. Duster [Re: F1Scamp] #3088242
10/22/22 08:05 AM
10/22/22 08:05 AM
Guitar Jones Offline
That is beautiful. Congratulations. You will have to change your signature line now.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: impressive run F.A.S.T. Duster [Re: INTMD8] #3088277
10/22/22 11:22 AM
10/22/22 11:22 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
If you're referring to taking advantage of the data logging feature then in a sense, yes. As I understand it, 'traction control" is about correlating wheel speed and driveshaft sensors (for example, could be any number of sensors/configurations) to see where it spins. With EFI you can obviously adjust both fuel and timing in those spots but the way the F.A.S.T. guys use the ECUs (carbureted) they're essentially limited to timing control.
The tires are a big part of the game. One racer laughed as he was telling me about buying a couple sets of $1,000 repro Polyglass tires and then shaving them down to the tread wear markers. Another guy told me 14" tires vs. 15" are worth a little bit of ET because of the weight.
'71 Duster
'17 Ram 1500
Re: impressive run F.A.S.T. Duster [Re: RMCHRGR] #3088292
10/22/22 12:14 PM
10/22/22 12:14 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I love the F.A.S.T. class racing. Makes me want to build one someday.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: impressive run F.A.S.T. Duster [Re: 6PKRTSE] #3088294
10/22/22 12:32 PM
10/22/22 12:32 PM
JCFcuda Offline
JCFcuda  Offline
That is a fantastic run congratulations .😎
Page 2 of 3 1 2 3
