Page 3 of 3 1 2 3
Re: Just installed an FBO box on my Hemi [Re: lewtot184] #3088088
10/21/22 02:30 PM
10/21/22 02:30 PM
Charlotte, NC
Kowal Offline OP
Kowal  Offline OP
Charlotte, NC
The box I used was the newest version, at least as of the last couple of years. I jumpered the ballast by replacing the resistor in the ceramic by an 10 gage wire. The distributor is a 1973 Mopar electronic ignition unit that I recurved and limited the advance on by using one of the FBO limiter plates. I mounted the ECU behind my front passenger headlight, to keep it away from heat and have the engine compartment continue to look stock.
I can’t speak to others’ issues. For me, the experience has been really positive. The difference between the FBO and other standard ECU’s is “seat of the pants” real.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Just installed an FBO box on my Hemi [Re: Kowal] #3088175
10/21/22 09:29 PM
10/21/22 09:29 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
7it certainly looks nice albeit not stock appearing. If one is putting that much effort into the box hopefully the same followed through to the electrical portion so you may be right. shruggy
So my next question would be what exactly have they done and could it be retrofitted to a "stock" appearing box for the resto guy's ?
Page 3 of 3 1 2 3
