The box I used was the newest version, at least as of the last couple of years. I jumpered the ballast by replacing the resistor in the ceramic by an 10 gage wire. The distributor is a 1973 Mopar electronic ignition unit that I recurved and limited the advance on by using one of the FBO limiter plates. I mounted the ECU behind my front passenger headlight, to keep it away from heat and have the engine compartment continue to look stock.
I can’t speak to others’ issues. For me, the experience has been really positive. The difference between the FBO and other standard ECU’s is “seat of the pants” real.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at
www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
