Painting Transmission #3086598
10/16/22 06:24 PM
10/16/22 06:24 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Just wanted to ask how others feel about painting a transmission. I'm debating whether or not to paint my 727 before I install it.
Re: Painting Transmission [Re: 6PAX] #3086605
10/16/22 06:46 PM
10/16/22 06:46 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Naw. Leave it raw finished.
Re: Painting Transmission [Re: Neil] #3086635
10/16/22 08:28 PM
10/16/22 08:28 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
It will stay nicer painted. As cast paint would be a good choise
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Painting Transmission [Re: 6PAX] #3086637
10/16/22 08:32 PM
10/16/22 08:32 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Paint the pallet instead.
Re: Painting Transmission [Re: Neil] #3086638
10/16/22 08:32 PM
10/16/22 08:32 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I've seen them painted silver, looks like a lot of wort that was hardly noticed.
I've seen them painted black, those kind of get lost under the vehicle.
I had a 4x4 unit painted blue, looked really out of place against the orange small block in the truck, but it was a great trans, 12 years of plowing snow without an issue. It got broken when the truck got wrecked.
Painting a trans is a lot of work for something pretty hard to see most of the time, imho.
Re: Painting Transmission [Re: 6PAX] #3086643
10/16/22 08:43 PM
10/16/22 08:43 PM
If you want to keep some more heat in it, paint it.
If not don't twocents
Re: Painting Transmission [Re: poorboy] #3086644
10/16/22 08:45 PM
10/16/22 08:45 PM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
Have used Dull Aluminum Lacquer in a rattle can on transmissions. Works well.
Don't need to get it on real heavy, just enough to where it looks nice.
Re: Painting Transmission [Re: 340SIX] #3086783
10/17/22 10:35 AM
10/17/22 10:35 AM
moparx Offline
moparx  Offline
send the case to 340SIX. he will POLISH it for you................ devil whistling boogie bow
beer
Re: Painting Transmission [Re: moparx] #3086917
10/17/22 05:19 PM
10/17/22 05:19 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
unless you have a see thru floor, the only part you see is the bell housing from the top..My Cudas still has the yellow and black stripes from Fairbanks...or a silver gray paint from another company.
Re: Painting Transmission [Re: 6PAX] #3086994
10/17/22 09:50 PM
10/17/22 09:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I've used plasti Kote rebuilders cast finish with good results and just looked at AMZ for cast aluminum paint. Holy cr-p Uncle joes economics are really driving the prices up. Did also see this which is very reasonably priced. I like others usually just fog it on to get a clean even look.
Aluminum paint
Re: Painting Transmission [Re: 6PAX] #3087078
10/18/22 08:25 AM
10/18/22 08:25 AM
an8sec70cuda Offline
No paint.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Painting Transmission [Re: 340SIX] #3087136
10/18/22 12:18 PM
10/18/22 12:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Painting seals the pores in the casting, dirt won't cling as readily as bare.
Re: Painting Transmission [Re: John_Kunkel] #3087147
10/18/22 12:55 PM
10/18/22 12:55 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I want stuff to look nice. I don't want it to look like I just pulled it out of an old truck in the junkyard.. If I can clean it to suit me, I leave it. If not, it gets cast iron color high heat paint.
Some castings are smother than others. I've had some Glide cases that were nice and cleaned up well.
Oven cleaner and elbow grease. I don't like to glass bead that stuff.
Re: Painting Transmission [Re: CMcAllister] #3087161
10/18/22 01:40 PM
10/18/22 01:40 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Candy Apple Red with gold leaf edging, or a carbon fiber wrap. smirk
Floyd Lippencott IV
Re: Painting Transmission [Re: mr_340] #3087186
10/18/22 03:30 PM
10/18/22 03:30 PM
340SIX Offline
340SIX  Offline
Add some hand laid pin stripes and ya talking.
As cast, dull aluim. Krylon and may others are a great chosie instead of a porous surface that will stain and dirty easy.
Light coat fogged on is best. Even Duplicolor silver engine works good but light costs from a distance will give a non gloss look
I was forgetting about VHT plus many other good spray bombs out there.
Re: Painting Transmission [Re: 340SIX] #3087235
10/18/22 05:17 PM
10/18/22 05:17 PM
moparx Offline
moparx  Offline
i recently did some wheels with rustoleum "implement" spray bombs, over their etching primer on the bare [blasted] wheels.
i used "massey -ferguson" gray. it turned out really nice.
i was surprised that it only took two coats per wheel [the face only] and i didn't use up one can !
the back sides and the barrel of the wheel the tire rides on, was painted with red oxide rustoleum and their regular black spray bombs.
i can't remember just how many colors the "implement" spray bombs come in, but if the other colors spray out as nice as mine did, and you can find a color you can live with, that may be an alternative.
i know regular automotive paint can stand up to engine heat, so i would think a quality spray bomb may do the same.
i think the secret in the spray bomb comment is the word "quality".
unfortunately, someone has to try it to see.
i am seriously considering using the "implement" paint on the 440 and 727 i have almost ready to install into my charger, so i may end up being the one to find out how it stands up.
beer
Re: Painting Transmission [Re: 6PAX] #3087556
10/19/22 06:10 PM
10/19/22 06:10 PM
Chicago-area Illinois
4mopower Offline
4mopower  Offline
Buddy of mine soda blast them first then clear coats.
Re: Painting Transmission [Re: 4mopower] #3087572
10/19/22 07:12 PM
10/19/22 07:12 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
My son painted his after we blasted the case and rebuilt it.
