Re: Painting Transmission
[Re: 6PAX]
#3086643
10/16/22 08:43 PM
10/16/22 08:43 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
If you want to keep some more heat in it, paint it. If not don't
[Re: poorboy]
#3086644
10/16/22 08:45 PM
10/16/22 08:45 PM
Posts: 1,840 South Bend
John Brown
South Bend
Have used Dull Aluminum Lacquer in a rattle can on transmissions. Works well.
Don't need to get it on real heavy, just enough to where it looks nice.
[Re: 6PAX]
#3087078
10/18/22 08:25 AM
10/18/22 08:25 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
[Re: 340SIX]
#3087136
10/18/22 12:18 PM
10/18/22 12:18 PM
Posts: 25,871 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It will stay nicer painted. As cast paint would be a good choise Painting seals the pores in the casting, dirt won't cling as readily as bare.
[Re: John_Kunkel]
#3087147
10/18/22 12:55 PM
10/18/22 12:55 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I want stuff to look nice. I don't want it to look like I just pulled it out of an old truck in the junkyard.. If I can clean it to suit me, I leave it. If not, it gets cast iron color high heat paint.
Some castings are smother than others. I've had some Glide cases that were nice and cleaned up well.
Oven cleaner and elbow grease. I don't like to glass bead that stuff.
[Re: mr_340]
#3087186
10/18/22 03:30 PM
10/18/22 03:30 PM
Posts: 28,600 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Candy Apple Red with gold leaf edging, or a carbon fiber wrap. Add some hand laid pin stripes and ya talking. As cast, dull aluim. Krylon and may others are a great chosie instead of a porous surface that will stain and dirty easy. Light coat fogged on is best. Even Duplicolor silver engine works good but light costs from a distance will give a non gloss look I was forgetting about VHT plus many other good spray bombs out there.
[Re: 340SIX]
#3087235
10/18/22 05:17 PM
10/18/22 05:17 PM
Posts: 19,470 north of coder
moparx
i recently did some wheels with rustoleum "implement" spray bombs, over their etching primer on the bare [blasted] wheels. i used "massey -ferguson" gray. it turned out really nice. i was surprised that it only took two coats per wheel [the face only] and i didn't use up one can ! the back sides and the barrel of the wheel the tire rides on, was painted with red oxide rustoleum and their regular black spray bombs. i can't remember just how many colors the "implement" spray bombs come in, but if the other colors spray out as nice as mine did, and you can find a color you can live with, that may be an alternative. i know regular automotive paint can stand up to engine heat, so i would think a quality spray bomb may do the same. i think the secret in the spray bomb comment is the word "quality". unfortunately, someone has to try it to see. i am seriously considering using the "implement" paint on the 440 and 727 i have almost ready to install into my charger, so i may end up being the one to find out how it stands up.
