Storage of removed door in trailer #3086105
10/14/22 09:05 PM
10/14/22 09:05 PM
VT
MOPARCRAZY Offline OP
VT
Looking for ideas for best wall mount storage of driver door removed while in trailer. I see some bracket kits but seem expensive for what they are. Any other hanger ideas? I would appreciate any pics.
Re: Storage of removed door in trailer [Re: MOPARCRAZY] #3086108
10/14/22 09:11 PM
10/14/22 09:11 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Man I wish I had pictures of the setup I had in my trailer for my Daytona door. The pins slid down in some collars and the door locked on a weld on door striker. A Moparts member has my Daytona but I’m not sure he uses that system. Hopefully he sees this.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Storage of removed door in trailer [Re: pittsburghracer] #3086115
10/14/22 09:37 PM
10/14/22 09:37 PM
VT
VT
Thanks for the reply. I am sure someone here has a good set up tp share.
Re: Storage of removed door in trailer [Re: MOPARCRAZY] #3086197
10/15/22 10:51 AM
10/15/22 10:51 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Temporary (like at the track) or while traveling ?
The fold-down bike or tool brackets I've bought from Home Depot would work for that at the track; trailer-mounting would require some cleverness.
Re: Storage of removed door in trailer [Re: topside] #3086216
10/15/22 11:39 AM
10/15/22 11:39 AM
VT
VT
Mounting in the trailer while traveling is my goal. Some type of hanging brackets maybe?
Re: Storage of removed door in trailer [Re: MOPARCRAZY] #3086225
10/15/22 12:00 PM
10/15/22 12:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have always used the RJ kit on both gutted steel and glass doors. Never and issue with it but make sure you go into a stud for the latch..
https://quartermax.com/door-hanger-kit/
Re: Storage of removed door in trailer [Re: Al_Alguire] #3086538
10/16/22 03:17 PM
10/16/22 03:17 PM
moparx Offline
moparx  Offline
one could always use some 1/4"x2" or 3" [or whatever width needed to weld on a spare set of hinge plates and latch mechanism] strap steel to span between studs if the door is shorter than the stud spacing would allow all parts of the door mounting mechanism to attach to.
beer
Re: Storage of removed door in trailer [Re: moparx] #3086768
10/17/22 10:07 AM
10/17/22 10:07 AM
VT
VT
Thanks for both ides. I did see the kit but I may look if I have extra hinges laying around, should be able to build something for less.
Thanks Moparts
