Internal Regulated Alternator #3083884
10/06/22 05:32 PM
10/06/22 05:32 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
I have a 66 Plymouth Satellite and want to put a bigger amp alternator on it. It has an extenrnal regulater and I'm wondering what I"d have to do to put one on.I'm looking to go to 100 to 130 amp
Re: Internal Regulated Alternator [Re: RBSat66] #3083890
10/06/22 06:11 PM
10/06/22 06:11 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
The regulator has little to do with output and is the simplest part to change.
It's the rest of the charging system that needs replacing and upgrading. Wires, ammeter, fuse links and likely even belt and pulley arrangements like going to double belts.
What's your need for power?
Angry white pureblood male
Re: Internal Regulated Alternator [Re: ruderunner] #3083933
10/06/22 10:17 PM
10/06/22 10:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Internal Regulated Alternator [Re: TJP] #3083978
10/07/22 08:41 AM
10/07/22 08:41 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
X3 , you put that big an alternator in a car with stock wiring and you're going to smoke the wiring harness if the system asks for anything over wha tthe stock system is rated for , and even then you're on borrowed time.
Re: Internal Regulated Alternator [Re: RBSat66] #3083982
10/07/22 09:04 AM
10/07/22 09:04 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I would think all you need is a Denso conversion. i know quite a few cars with just a 60-80 amp Denso alternator and they do fine even with big fuel pumps,fans and electric water pumps. twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Internal Regulated Alternator [Re: fourgearsavoy] #3084042
10/07/22 12:08 PM
10/07/22 12:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Gus beer
Not trying to be offensive but Doing so on a late 70's and up vehicle that MAY have come with a 60 + amp alternator one would likely be OK. But on an earlier vehicle with a 35-40 Amp system that is BALLSY. tsk panic
Re: Internal Regulated Alternator [Re: TJP] #3084067
10/07/22 01:41 PM
10/07/22 01:41 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I use a GM CS130 alternator, they are 105amp internally regulated. I wire mine with a charge light and a sense wire. The only factory wiring on my car is lights and wipers though.
I run EFI, 4000CFM fan, electric water pump, electric fuel pumps etc.
68 Barracuda Formula S 340
Re: Internal Regulated Alternator [Re: Bad340fish] #3084111
10/07/22 05:53 PM
10/07/22 05:53 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
If those high draw items are powered directly off the alternator, you might get away with not upgrading the rest of the wiring. Better safe than sorry though.
Re: Internal Regulated Alternator [Re: ruderunner] #3084118
10/07/22 06:32 PM
10/07/22 06:32 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
What else needs upgraded? A load will only draw as much as it needs. For example, the tail lights are not going to take any more current than they did with the original alternator.
What ever additional high current loads that may be added would need appropriate sized wiring to handle those loads and some thought as to where to feed them from, but nothing stock is, assuming a good condition harness.
When I updated my 51 Plymouth to a 78A 12v alternator I used the battery side connection of the fender mounted starter solenoid as the tie point to feed my electric fan relays (24A draw on high) and to tie the output of the alternator to. The aftermarket gauge kit I am running has no ammeter so I didn't have to concern myself with that. The EFI feed comes from there too. The rest of the wiring harness is a generic 12v spec 21 circuit harness. When I get around to adding AC I will feed that relay from the same point.
Re: Internal Regulated Alternator [Re: Sniper] #3084120
10/07/22 07:03 PM
10/07/22 07:03 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You're increasing amperage output, not voltage. The various items will only draw the amperage they need.
Re: Internal Regulated Alternator [Re: RBSat66] #3084200
10/08/22 03:03 AM
10/08/22 03:03 AM
Cab_Burge Online work
Cab_Burge  Online Work
I bought and used a Power master 100 Amp single wire alternator on my last street and drag race car, I ran an 8-gauge wire straight from the alternator to the positive post on the battery and added a volt gauge from the ignition side from the stock fuse box. I disconnected and didn't use any part of the original charging circuit, I did have to back feed from the battery back to the ignition switch to make the new alternator work in that 1971 Duster wrench up
As already mentioned, you can't safely run a lot more current, 80 Amps+, amperage, through the early low amperage stock factory wiring tsk
IHThs up
Mopar cars in 1969 had a bad reputation on the entire electrical system, many caught on fire and burnt to the ground due to the issues in the wiring puke
Re: Internal Regulated Alternator [Re: Sniper] #3084220
10/08/22 07:52 AM
10/08/22 07:52 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
As noted where you take the load from is important. But let's say something goes wrong with the battery, the alternator will power through the original wiring until it melts. Big problem. Especially with known weak points like the bulkhead connector.
I've seen too many rolling fire hazards, usually related to stereo systems.
Re: Internal Regulated Alternator [Re: ruderunner] #3084259
10/08/22 10:53 AM
10/08/22 10:53 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I forgot to mention the part where I upgraded the feed from the alternator output to the battery. It's rated to handle the full output of the alternator, actually I upsized one size, belt and suspenders. Every high load draw is also protected by fusible links.
Re: Internal Regulated Alternator [Re: Sniper] #3084344
10/08/22 03:13 PM
10/08/22 03:13 PM
moparx Offline
moparx  Offline
how about having a high amp draw "strip", where the new high amp accessories [with relays] can be fed from, bypassing the bulkhead amp gauge, and keeping the fusible links for the rest of the system ? [as well as incorporating the necessary fusible links or other means to protect the high amp draw circuits]
and connecting the alternator output stud to the battery as has been mentioned [by way of the stud on the starter relay].
beer
Re: Internal Regulated Alternator [Re: moparx] #3084383
10/08/22 06:04 PM
10/08/22 06:04 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
That's what we're discussing. Taking the add on high draw stuff from the alternator and essentially bypassing the stock wiring. I still contend it's a good idea to upgrade the original wiring to handle the potential of carrying the full output of the alternator.
Re: Internal Regulated Alternator [Re: Cab_Burge] #3084385
10/08/22 06:12 PM
10/08/22 06:12 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
IHThs up
I agree with Cab. Upgrade wiring too, and Power Master has some nice quality stuff. Just look at the 70's Dodge trucks to realize the problems with wiring and bulkheads, etc.
Facts are stubborn things.
Re: Internal Regulated Alternator [Re: ruderunner] #3086894
10/17/22 03:52 PM
10/17/22 03:52 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
My amp guage is reads low at idle even when only supplyingpower just for fuelpump and motor. it gets worse as headlights or heat motor is used. it will go back up to charge when at about 1500 rpms. just concerned.
Re: Internal Regulated Alternator [Re: RBSat66] #3086968
10/17/22 08:21 PM
10/17/22 08:21 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Mopar alternators are notoriously weak at low rpm. Even worse If you have an under drive pulley.
Re: Internal Regulated Alternator [Re: RBSat66] #3086990
10/17/22 09:37 PM
10/17/22 09:37 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Have you checked for Voltage drops in your system? IE: what is the alternator stud reading vs what the battery is seeing at idle and 2,00RPM? It's not uncommon for the drops that are normally caused by poor connections to cause your condition. the other issue already mentioned is pulley sizing, but if you have multiple voltage drops upping the alternator output by whatever method is a band-aid. You should also have the alternator checked for output referencing the factory service manual twocents beer
