speedometer cable #3082541
10/02/22 06:38 PM
10/02/22 06:38 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
So, this happened while installing a brand new speedo cable. Does anyone sell just the plastic end or do I need to purchase another brand new cable?
Re: speedometer cable [Re: burdar] #3082542
10/02/22 06:44 PM
10/02/22 06:44 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I never seen the end sold separately. You need a new cable. I would try and find a mopar one. I had bad luck with aftermarket speedo cables.
Re: speedometer cable [Re: mopars4ever] #3082559
10/02/22 07:53 PM
10/02/22 07:53 PM
BDW Offline
BDW  Offline
Epoxy it back together, not much stress on that cable
Re: speedometer cable [Re: burdar] #3082597
10/02/22 10:52 PM
10/02/22 10:52 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Put a small hose clamp around it.
Re: speedometer cable [Re: BDW] #3082601
10/02/22 11:08 PM
10/02/22 11:08 PM
iagree
Or take it back and get it exchanged for better brand work up twocents
Re: speedometer cable [Re: PhillyRag] #3082602
10/02/22 11:10 PM
10/02/22 11:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
super glue will hold that.
Re: speedometer cable [Re: stumpy] #3082646
10/03/22 09:17 AM
10/03/22 09:17 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
This was supposed to be a good one that Rick Ehrenberg sold on his e-bay store.
I hooked it up to the dash cluster with the dash assembly pulled away from the windshield. I think it bound up as I rotated the dash into place. After the fact I realized that it was easily accessible from under the dash and I didn't need to plug it into the cluster when I did.
Re: speedometer cable [Re: burdar] #3082688
10/03/22 11:44 AM
10/03/22 11:44 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Contact Rick, Worth a shot.
Re: speedometer cable [Re: mopars4ever] #3083027
10/03/22 08:40 PM
10/03/22 08:40 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
I can see maybe an old aged one breaking. But a new clip material should have some "give" to it.
I say flaw, or just plain cheap material.
Have seen many clips break off, but never that.
Re: speedometer cable [Re: PhillyRag] #3083155
10/04/22 09:22 AM
10/04/22 09:22 AM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
I would drill and pin both sides carefully and wrap fiberglass cloth once around it and put resin over the glass. Tape off the areas you don't want the resin to come in contact with.
Re: speedometer cable [Re: CYACOP] #3083163
10/04/22 09:43 AM
10/04/22 09:43 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I super glued it last night. After the main piece was glued to the end of the cable, I built up the area around the crack with glue and sprinkled backing soda on it to turn it into a plastic like substance. I'll see how strong it feels tonight.
Re: speedometer cable [Re: burdar] #3083167
10/04/22 10:02 AM
10/04/22 10:02 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I would suspect the rest of the plastic is just as brittle as the part that broke.
Re: speedometer cable [Re: Sniper] #3083184
10/04/22 10:47 AM
10/04/22 10:47 AM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
I'm pretty sure that ATC is the only manufacturer making cables and they call come from the same source.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: speedometer cable [Re: shanker] #3083340
10/04/22 06:43 PM
10/04/22 06:43 PM
moparx Offline
moparx  Offline
use some "marine grade" heat shrink over that repair.
it has "glue" in it, and will help keep the super glue repair intact.
i'm almost positive you can get it in white, and the right size for use on that cable end.
beer
