Re: speedometer cable
[Re: burdar]
#3082542
10/02/22 06:44 PM
10/02/22 06:44 PM
Posts: 13,601 md
mopars4ever
md
I never seen the end sold separately. You need a new cable. I would try and find a mopar one. I had bad luck with aftermarket speedo cables.
[Re: Sniper]
#3083184
10/04/22 10:47 AM
10/04/22 10:47 AM
Posts: 5,784 Corpus Christi, TX
shanker
Corpus Christi, TX
I'm pretty sure that ATC is the only manufacturer making cables and they call come from the same source.
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: shanker]
#3083340
10/04/22 06:43 PM
10/04/22 06:43 PM
Posts: 19,459 north of coder
moparx
use some "marine grade" heat shrink over that repair. it has "glue" in it, and will help keep the super glue repair intact. i'm almost positive you can get it in white, and the right size for use on that cable end.
