Re: Indy max lifters
[Re: 340KID]
#3107276
01/01/23 04:47 PM
01/01/23 04:47 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
Most of The early non pressurized solid roller lifter uses splash oil to lube the needles and axles from the crankshaft oiling being thrown out as they revved up thank you, so is it preferred to use needle style vs bushed ? It probably depends on who you talk to and what their using them on and for what application their using them in. I have not used bush solid roller lifters yet, but I buy the best solid roller lifters I can get like the Crower big wheel race lifters We need some racers on here who are using them, bushed solid roller lifters, to chime in on what they think and have found on them
[Re: 340KID]
#3107282
01/01/23 05:25 PM
01/01/23 05:25 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Call brad at BAM, he WILL talk your ear off about lifters. LOL FYI, without pressure, you will need to go to needles for splash oiling.
Joe
Without Data, you’re just another guy with an opinion.
[Re: 340KID]
#3107780
01/02/23 07:28 PM
01/02/23 07:28 PM
Posts: 1,212 Minn
SportF
Minn
I've had bushed roller lifters (Howards) in my max block for 600 passes now. No trouble with the splash lube so far. I do change oil often, maybe that helps. Motor was inspected at 320 runs, freshened at 500 runs.
[Re: SportF]
#3108045
01/03/23 02:44 PM
01/03/23 02:44 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I just got a set of BAM bushed lifters , from Dwayne Porter, for an Indy Max block build, BAM says and thinks they will be fine with splash oiling. That build is going together and waiting for parts now.
