lifters #3081991
09/30/22 12:58 PM
09/30/22 12:58 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Going to be purchasing a new solid flat tappet cam. Looking at lifters and see some now are direct lube lifters (have small hole in bottom of the lifter). Any reason not to get the direct lube lifters? Seems like it would be extra helpful with today's cams which seem more prone to eating a lifter.
Re: lifters [Re: DusterKid] #3081995
09/30/22 01:05 PM
09/30/22 01:05 PM
NC
440Jim Offline
440Jim  Offline
NC
I like those direct lube lifters with the oil hole on the face.
Some brands might need different length pushrods, so check it. twocents
Re: lifters [Re: DusterKid] #3081997
09/30/22 01:16 PM
09/30/22 01:16 PM
Most stock unbushed lifter bore blocks leak a ton of oil around the lifters flooding the cam lobes, maybe you should check yours to see how much yours leak now scope twocents
The reason that some lifter company started adding the direct lube holes on the bottom were for BB Chevy, not for Mopar motors shruggy scope
Re: lifters [Re: 440Jim] #3082029
09/30/22 04:09 PM
09/30/22 04:09 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used Howards EDM lifters on my current flat tappet cam and no issues. I think they are AMC lifters because they oil through the the pushrods and they are 1/8 taller than my old Comps so yes some brands my be taller.
Gus beer
64 Plymouth Savoy
Dana 60
Re: lifters [Re: DusterKid] #3082062
09/30/22 07:50 PM
09/30/22 07:50 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
I use PPP tool steel lifters on my AMC stocker. They have the EDM hole on the face. You almost need a magnifying glass to see it, it’s that small.
1979 AMC Spirit, NHRA Q/SA
Re: lifters [Re: longram60] #3082074
09/30/22 08:18 PM
09/30/22 08:18 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I had five years on my EDM lifters from Hughs on a .650 lift cam in my small block. I didn’t mic everything yet but they look good and the car was still running 6.0’s.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: lifters [Re: Cab_Burge] #3082080
09/30/22 08:39 PM
09/30/22 08:39 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Since the edms are pressurized right on the lobe wouldnt one think its many many times better then splashed oil? Just setting up a cam we see how much oil/lube the lifter wipes off the lobe. Just on setup lashing the valves I see the lobes start to wipe dry so every 2-3 turns I got the oil can out, looks to do the same with cam lube.
So why wouldnt pressurized oil from the lifter base to lobe not be very helpful?
STOP POTATO HATE!
Re: lifters [Re: DusterKid] #3082086
09/30/22 08:57 PM
09/30/22 08:57 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I have comp cams e.d.m. lifters on my bullet cam. #155 seat, #350 open. No problems for 5 years. Hole is supposed to be .021" and look like it too.
