1969 B-Body Gas Pedal Bracket Color - Black or Natural?
#3079860
09/23/22 09:23 AM
09/23/22 09:23 AM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
I'm putting a new carpet in my Charger and I figured I'd detail a few other things. The Gas pedal bracket under the dash that bolts to the firewall appears to be original and had a light patina on it. I popped it in the glass bead cabinet and couldn't find any residual black paint. Looking at some restored cars, it looks like this bracket is painted flat or satin black. What is the consensus here, natural or black?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: 1969 B-Body Gas Pedal Bracket Color - Black or Natural?
[Re: gtx6970]
#3080427
09/25/22 02:20 AM
09/25/22 02:20 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Black phosphate.
Looks like a real dark flat grey Otherwise known as Parkerizing or manganese phosphate, the same finish as on military firearms since WWI and many tools. Also the same finish as on most Mopar fasteners and drum brake backing plates. Relatively cheap and easy to do with stainless pots, gunsmithing chemicals, and a stable electric heat source that will hold the chemicals at 190 degrees F, and a good thermometer. A camp stove will not work. Parts must be clean, bare metal - I cleaned with vinegar and wire brushing with very good results. For parts to be left unpainted, coat with RPM wax which darkens.
[Re: kentj340]
#3080438
09/25/22 08:18 AM
09/25/22 08:18 AM
RSI700VIPER
NW New Jersey
Kent - That's some lab you got set up there. Parts look great. I've used the cold applied block phosphate (blue liquid) that got from Casswell (spelling). You dip a clean bolt or bracket in a 90-10 water/phosphate solution for about 10 minutes. Turns the part black but leaves a slight rust color residue and doesn't really last long unless you clearcoat it. Your process seems much more durable.
[Re: RSI700VIPER]
#3080718
09/26/22 03:21 AM
09/26/22 03:21 AM
kentj340
Cut and Shoot, TX
Yes, there’s a very good reason that military firearms (and Mopar fasteners, gas pedal brackets, and brake backing plates) are surface finished with Parkerizing or manganese phosphating, a hot process, rather than the Caswell black oxide cold process.
