1969 B-Body Gas Pedal Bracket Color - Black or Natural? #3079860
09/23/22 09:23 AM
09/23/22 09:23 AM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
I'm putting a new carpet in my Charger and I figured I'd detail a few other things. The Gas pedal bracket under the dash that bolts to the firewall appears to be original and had a light patina on it. I popped it in the glass bead cabinet and couldn't find any residual black paint. Looking at some restored cars, it looks like this bracket is painted flat or satin black. What is the consensus here, natural or black?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: 1969 B-Body Gas Pedal Bracket Color - Black or Natural? [Re: RSI700VIPER] #3079865
09/23/22 09:48 AM
09/23/22 09:48 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Both my Challenger and my Dart had some type of gray coating on the gas pedal arm and bracket. Maybe phosphate? They weren't painted but weren't bare metal either.
Re: 1969 B-Body Gas Pedal Bracket Color - Black or Natural? [Re: burdar] #3080189
09/24/22 08:49 AM
09/24/22 08:49 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Black phosphate.
Looks like a real dark flat grey
Re: 1969 B-Body Gas Pedal Bracket Color - Black or Natural? [Re: gtx6970] #3080427
09/25/22 02:20 AM
09/25/22 02:20 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Originally Posted by gtx6970
Black phosphate.
Otherwise known as Parkerizing or manganese phosphate, the same finish as on military firearms since WWI and many tools.
Also the same finish as on most Mopar fasteners and drum brake backing plates. Relatively cheap and easy to do with stainless pots, gunsmithing chemicals, and a stable electric heat source that will hold the chemicals at 190 degrees F, and a good thermometer. A camp stove will not work. Parts must be clean, bare metal - I cleaned with vinegar and wire brushing with very good results. For parts to be left unpainted, coat with RPM wax which darkens.
Re: 1969 B-Body Gas Pedal Bracket Color - Black or Natural? [Re: kentj340] #3080438
09/25/22 08:18 AM
09/25/22 08:18 AM
NW New Jersey
NW New Jersey
Kent - That's some lab you got set up there. Parts look great. I've used the cold applied block phosphate (blue liquid) that got from Casswell (spelling). You dip a clean bolt or bracket in a 90-10 water/phosphate solution for about 10 minutes. Turns the part black but leaves a slight rust color residue and doesn't really last long unless you clearcoat it. Your process seems much more durable.
Re: 1969 B-Body Gas Pedal Bracket Color - Black or Natural? [Re: RSI700VIPER] #3080718
09/26/22 03:21 AM
09/26/22 03:21 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Yes, there’s a very good reason that military firearms (and Mopar fasteners, gas pedal brackets, and brake backing plates) are surface finished with Parkerizing or manganese phosphating, a hot process, rather than the Caswell black oxide cold process.
