Trim Ring Question #3079861
09/23/22 09:25 AM
09/23/22 09:25 AM
White Plains NY
VitaminCRunner Offline OP
White Plains NY
Trying to get my runner back on the road and need some help on trim rings on repro wheel vintique 15x7 rally wheels. The photos below show the two I but dont like either. The wheel vintique polished versions seem to reflect the holes in the wheels and look too new. The stock ones I have dont go all the way into the rim but i like the way they look much better. I assume because mopar made 6.5" wheels that these are too thin. Do they make 3" in this style. Any help or thoughts appreciated.
Re: Trim Ring Question [Re: VitaminCRunner] #3080009
09/23/22 03:19 PM
09/23/22 03:19 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Mopar made 3" deep trim rings for the 70-72 style 15x7 rims.They made polished and brushed versions....keep an eye open for them. However, be prepared for sticker shock. Damaged cores bring $150+ each. Restored set of 4 = $2000 or More. NOS set of 4 $4000+
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Trim Ring Question [Re: VitaminCRunner] #3080058
09/23/22 05:31 PM
09/23/22 05:31 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Take the polished ones and brush them to your desired texture.
Re: Trim Ring Question [Re: 71birdJ68] #3080134
09/23/22 09:41 PM
09/23/22 09:41 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
up easily done with the rear end on jackstands, a bare wheel mounted to the axle with trim ring installed. Tthe motor idling in gear and a ultra fine scothbrite pad. Too dull, polish a bit using same method. beer
Re: Trim Ring Question [Re: 70gtx440dana] #3080143
09/23/22 10:18 PM
09/23/22 10:18 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
…the reason I run my brushed 15x7 wheel vintiques trim rings on my 390’s for driving and save my mint brushed OE 15x7’s
Re: Trim Ring Question [Re: TJP] #3080267
09/24/22 01:12 PM
09/24/22 01:12 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
this works, i'd spray a little wd40 on the ring first, for lube.
Re: Trim Ring Question [Re: Golden-Arm] #3083278
10/04/22 04:02 PM
10/04/22 04:02 PM
moparx Offline
moparx  Offline
and keep your fingers out of the valve stem hole............ biggrin whistling panic laugh2
beer
