Need a bolt hole dimension - Small Block #307912
05/04/09 06:29 PM
05/04/09 06:29 PM
In the twisties
RokketRide Offline OP
super gas
super gas
In the twisties
On the front of some small blocks there is a bolt hole just above and outboard of the freeze plug (driver side).
If anyone has convenient access, I would like to find out the depth. Would prefer not to hit water if I end up drilling it out.
Re: Need a bolt hole dimension - Small Block [Re: RokketRide] #307913
05/05/09 11:37 AM
05/05/09 11:37 AM
In the twisties
super gas
super gas
In the twisties
Day crew, help me out.
Re: Need a bolt hole dimension - Small Block [Re: RokketRide] #307914
05/05/09 11:46 AM
05/05/09 11:46 AM
a cornfield near you
BlakDak Offline
BlakDak  Offline
so you want to know how deep the hole is? or how far you can go till you hit water?
Re: Need a bolt hole dimension - Small Block [Re: BlakDak] #307915
05/05/09 11:51 AM
05/05/09 11:51 AM
In the twisties
super gas
super gas
In the twisties
Right, I want to avoid hitting water. No idea what the casting thickness is there.
My engine doesnt have this hole drilled ...yet.
Re: Need a bolt hole dimension - Small Block [Re: RokketRide] #307916
05/05/09 11:58 AM
05/05/09 11:58 AM
BlakDak Offline
BlakDak  Offline
off the to of my head, I think the bolt that goes in that hole is 3/4 long.
I can measure a bare block, and let you know how deep the hole is tonight.
Re: Need a bolt hole dimension - Small Block [Re: RokketRide] #307917
05/05/09 12:02 PM
05/05/09 12:02 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Couldn't you knock out the freeze plug then measure the thickness of the block there with a caliper,micrometer,etc ?
Re: Need a bolt hole dimension - Small Block [Re: OzHemi] #307918
05/05/09 12:39 PM
05/05/09 12:39 PM
In the twisties
super gas
super gas
In the twisties
That would be one way to go Jeff, but I'd rather not have to drain and fill if I dont have to.
Re: Need a bolt hole dimension - Small Block [Re: RokketRide] #307919
05/05/09 12:45 PM
05/05/09 12:45 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Gotcha...since you mentioned having to drill the hole, I assumed it was out of the car perhaps
At least if you went too deep with the hole, you could always use sealant on the threads.
Re: Need a bolt hole dimension - Small Block [Re: BlakDak] #307920
05/05/09 10:46 PM
05/05/09 10:46 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I would say that sounds about right. I recall trying to get a P/S pump bracket bolt in there and there was not a lot of depth.
Here's a
Re: Need a bolt hole dimension - Small Block [Re: In_The_Pink] #307921
05/06/09 12:06 AM
05/06/09 12:06 AM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Just measured with my caliper, 3/4" deep.
Re: Need a bolt hole dimension - Small Block [Re: Posest] #307922
05/06/09 12:57 AM
05/06/09 12:57 AM
In the twisties
super gas
super gas
In the twisties
Thanks a bunch.
All your work saves mine
